The Build: http://pcpartpicker.com/p/22peB
CPU: AMD FX-8350 4.0GHz 8-Core Processor ($184.99 @ NCIX US)
Motherboard: Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard ($114.99 @ NCIX US)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($87.32 @ NCIX US)
Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive ($84.65 @ OutletPC)
Video Card: MSI GeForce GTX 770 2GB Video Card ($334.98 @ SuperBiiz)
Case: NZXT Phantom 410 (Red) ATX Mid Tower Case ($84.99 @ Microcenter)
Power Supply: Antec High Current Gamer 750W 80+ Bronze Certified ATX Power Supply ($94.48 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.98 @ OutletPC)
Operating System: Microsoft Microsoft Windows 8.1 - 64-bit - OEM (64-bit) ($99.99 @ Newegg)
Total: $1103.37
Hi, first time PC builder here. I basically took this build from one of the high-rated Completed Builds on PcPartPicker. The only things I've changed was the color of the case, and I added Windows 8.1 OS since their original list didn't have an OS.
The reason why I took their build instead of making my own is because I don't know enough about compatibility to know what manufacturer parts work well with each other. I figured using one of the completed builds made by of high rated posts will ensure that the parts are compatible with each other, and that the parts' dimensions will fit into the case.
But I'd just like to get second opinions from you guys here to double check on that. I'd also like your opinions on whether you think some of the parts could be switched out with something cheaper (such as the motherboard or the PSU), and will still not interfere with compatibility and performance.
Notes*
- No additional CPU cooler because I will not be overclocking.
Total: $1103.37
Notes*
