Hey, I have pretty much everything in, I am just really confused on where some wires go and its a little overwhelming.
If someone can help direct me? Its really confusing...
Mind you this is absolute FIRST time ever trying to assemble a computer. I followed Neweggs video tutorial up until now where all my wires are just around.
And what is the HDA cable that came with case and what should that connect to?
And I can't tell which wire from the power supply I'm assuming connects to the DVD drive/HD
It looks like it has two different wire inputs is that to give you "options" depending on what power supply you got?
or do both need to have a wire going to them?
^ Is that correct? should the other side not be plugged in to anything?
Assuming not all of these wires get used? Do I need to use BOTH PCI-E cables or is it just one? I only have one video card.
These came with the mother board, are they needed or are they used for something else?
Thanks.
Thanks.
