First Build Problems - No display
Akhockey21
So After i put together a new build i made, i started the computer just fine. The error code on the MOBO was 00 with all the fans and CD drive/ HDD running, nothing came out on display and no beeping on case speaker.
After reviewing online i figured it had to be the PSU, so i unhooked the PSU from my old computer and swapped it with the one i just had, both computers now wont go to POST no matter what power supply i use.
I'm assuming the new power supply i got has damaged both my computer motherboards, hopefully that's all.
Just Hoping someone has insight on what i might have done wrong or a possible solution?
Thanks,
sincereley Brandon Howard
