First computer build / Need confirmation on parts please
Last Impulse
9
Hey all,
So I've begun to build myself a desktop (for gaming) but, have never done it before. I have basically finished selecting the parts with only a few problems--I'm not fully sure everything is compatible/good to be put together.
I used PcPartPicker.com to help pick the parts and it says it uses a compatibility filter so i'm pretty sure everything is compatible plus, i have personally read the specs fairly thoroughly. My only concern is some bad reviews from Newegg stating that my Motherboard isn't very good for my CPU and some other concerning things. If it wouldn't be too much to ask, could somebody please look through and help decide if my build should be acceptable?
Here is the build I'm looking at buying: http://pcpartpicker.com/p/2crIU
CPU--- AMD FX-8320 3.5GHz 8-Core Processor
CPU cooler--- Arctic Cooling Freezer 7 Pro Rev.2 45.0 CFM Fluid Dynamic Bearing CPU Cooler
Motherboard--- MSI 970A-G46 ATX AM3+ Motherboard
RAM sticks--- G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory
HDD--- Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
GPU--- MSI Radeon R9 270X 2GB Video Card
Full Tower Case--- Azza Genesis 9000 (White) ATX Full Tower Case
Power Supply--- Thermaltake Tough Power 750W 80+ Gold Certified ATX Power Supply
Fan--- Cooler Master R4-L2R-20AC-GP 69.0 CFM 120mm Fan
Thanks in advance. Also, my budget is like a deadline $900.
PCPartPicker part list: http://pcpartpicker.com/p/2cIWh
Price breakdown by merchant: http://pcpartpicker.com/p/2cIWh/by_merchant/
Benchmarks: http://pcpartpicker.com/p/2cIWh/benchmarks/
CPU: AMD FX-8320 3.5GHz 8-Core Processor ($129.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ NCIX US)
Motherboard: Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard ($104.98 @ SuperBiiz)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory ($52.99 @ Newegg)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($79.99 @ Newegg)
Video Card: XFX Radeon R9 280X 3GB Video Card ($309.98 @ SuperBiiz)
Wireless Network Adapter: TP-Link TL-WN881ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter...
M0kujin
202
PCPartPicker part list: http://pcpartpicker.com/p/2cwEJ
Motherboard: Asus M5A97 R2.0 ATX AM3+ Motherboard ($94.99 @ Amazon)
Memory: G.Skill Ripjaws X Series 8GB (1 x 8GB) DDR3-1600 Memory ($72.98 @ OutletPC)
Video Card: Asus Radeon R9 280X 3GB Video Card ($316.13 @ Newegg)
Wireless Network Adapter: Netgear WN311B-100NAS 802.11b/g/n PCI Wi-Fi Adapter ($24.99 @ Newegg)
Case: Azza Genesis 9000 (White) ATX Full Tower Case ($119.99 @ Newegg)
Case Fan: Cooler Master R4-L2R-20AC-GP 69.0 CFM 120mm Fan ($6.99 @ NCIX US)
Power Supply: Corsair Builder 600W 80+ Bronze Certified ATX Power Supply ($29.99 @ Newegg)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($14.99 @ Newegg)
Total: $903.02
I change your ram to 8gb, your motherboard to Asus, your PSU to corsair CX 600w, and finally you GPU to 280x.
you only need 8gb if you are using it mainly for gaming, and that 280x will play all games available today on maximum settings 1080p. if you want to upgrade your ram later, just upgrade it.
RazerZ
Judicious
Ambassador
A little over budget but the CPUs and mobo should go on sale tomorrow.
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($194.99 @ NCIX US)
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($99.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 770 2GB Video Card ($324.98 @ SuperBiiz)
Wireless Network Adapter: TP-Link TL-WN881ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter ($18.24 @ Amazon)
Case: Fractal Design Arc Midi R2 (Black) ATX Mid Tower Case ($49.99 @ Newegg)
Power Supply: Thermaltake Tough Power 750W 80+ Gold Certified ATX Power Supply ($54.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.98 @ OutletPC)
Total: $937.11
(Generated by PCPartPicker 2013-12-01 09:32 EST-0500)
Wireless Network Adapter: TP-Link TL-WN881ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter ($17.99 @ Microcenter)
Total: $861.85
(Generated by PCPartPicker 2013-12-01 12:26 EST-0500)
withing budget yes
RazerZ
Judicious
Ambassador
I would go with my build and do what Iceclock did if it's too much right now; just switch the cpu to a 8320 and adjust mobo accordingly.
Last Impulse
9
Alright guys! I've finally put together another build based off of the ones above. All that is left is for me to get a case and, due to my new graphic card selected, a new power supply. PcPartPicker is being dumb and saying the graphic card will use like around 235watts but, it is stated that the card has a system power supply requirement of 600W.
Um, can you guys help me with finding a case? It needs to be cheap ($50 and under) and decent looking but, capable of housing the graphic card with dimensions L=292mm W=129mm H=43mm. Also, i need help on picking a Power supply. Also needs to be cheap--This graphic card is making me borderline, if not surpass, my budget. Thanks and btw, here's the link to the new build.
http://pcpartpicker.com/user/LastImpulse/saved/3162
RazerZ
Judicious
Ambassador
Do you plan to add a second GTX 770 later on?
RazerZ
Judicious
Ambassador
Well here's what would look like if you don't plan on adding a second GPU.
Motherboard: Gigabyte GA-970A-UD3 ATX AM3+ Motherboard ($104.99 @ Mac Mall)
Video Card: Gigabyte GeForce GTX 770 4GB Video Card ($368.99 @ SuperBiiz)
Wireless Network Adapter: Rosewill RNX-N250PCe 802.11b/g/n PCI-Express x1 Wi-Fi Adapter ($14.99 @ Newegg)
Case: Rosewill BlackHawk ATX Mid Tower Case ($44.99 @ Newegg)
Case Fan: Cooler Master R4-L4S-10AB-GP 60.9 CFM 140mm Fan ($7.98 @ OutletPC)
Power Supply: XFX 650W 80+ Bronze Certified Semi-Modular ATX Power Supply ($39.99 @ Newegg)
Total: $891.87
(Generated by PCPartPicker 2013-12-01 22:58 EST-0500)
If you do then you will need a stronger PSU.
RazerZ
Judicious
Ambassador
650 should be fine but that PSU is a great deal so if you want to play it safe get it. Plus in the future you might end up getting another GPU or upgrading the system or something along those lines. If your getting that one it is at a great deal for it's price but that's because of Black Friday deals.
Last Impulse
9
Ok, so I'm going to get that X cruiser 2bk.
Uhh, it says it comes with 3 120mm fans so i'm assuming it is ok to remove my fans from my build? Or should I just keep them since they're fairly cheap?
Also, I am concerned with this "Fits Graphics Cards up to 11" in length" My Gtx 770 is 11.5 inches by 5 by 1.7... Do you think the extra half an inch will still fit?
(Worst comes to worst I'll just get my mechanic father to use power tools and adjust the case size.)
Here's the nearly final build guys! http://pcpartpicker.com/user/LastImpulse/saved/31Tb
Btw, you've all been so helpful.
RazerZ
Judicious
Ambassador
Alright here's what I would go with:
CPU: AMD FX-8320 3.5GHz 8-Core Processor ($129.99 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ Microcenter)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory ($52.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 770 4GB Video Card ($369.99 @ Amazon)
Wireless Network Adapter: Rosewill RNX-N250PCe 802.11b/g/n PCI-Express x1 Wi-Fi Adapter ($18.65 @ Amazon)
Case: NZXT Phantom 410 (White) ATX Mid Tower Case ($84.98 @ Amazon)
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply ($49.99 @ NCIX US)
Total: $928.54
(Generated by PCPartPicker 2013-12-02 19:51 EST-0500)
Now I know it has a different case, but if you don't like it you can change it to match yours. This case is a really solid one and many people have used it in their builds. Also if your going to go with a blue theme I would also wait till the blue G.Skill Ripjaws go on sale for $50.
PCPartPicker part list: http://pcpartpicker.com/p/2dRmQ
Price breakdown by merchant: http://pcpartpicker.com/p/2dRmQ/by_merchant/
Benchmarks: http://pcpartpicker.com/p/2dRmQ/benchmarks/
Motherboard: Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard ($89.99 @ Newegg)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory ($73.97 @ OutletPC)
Wireless Network Adapter: TP-Link TL-WN881ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter ($18.18 @ Amazon)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case ($69.99 @ NCIX US)
Power Supply: Thermaltake Tough Power 750W 80+ Gold Certified ATX Power Supply ($79.99 @ Newegg)
Total: $913.03
(Generated by PCPartPicker 2013-12-02 19:56 EST-0500)
black pearls is so sexy and on sale :)
