First Computer Building Help :D
Elvis N YoonA
91
Hi,
I am building a computer soon,My fund is about $1100
Motherboard:
Asrock Z77 Extreme4
CPU Cooler : Cooler Master Hyper 212 EVO Turbo Intel+AMD Cooler
Processor:
Intel Core i5 3570k 3.40GHz 6MB
GPU:
SAPPHIRE HD7870 XT WITH BOOST
RAM:
Kingston HyperX 8GB(2x4GB) 1600MHz DDR3(Is this good? because somebody tell me i should change this because of the voltage)
Harddisk :
Western Digital Carviar Black 1TB
Casing:
Cooler Master Centurion 6 Mid Tower
Casing Fan : Cooler Master 12CM Silent Fan Blue LED 120MM(Maybe getting extra 4 fan < is this needed??)
PSU:
Thermaltake TR2 700W Cable Management Optimized Power Supply
Random DVD-R
How much is the total all of this and is it combatible with each others??
*Note*:I am from malaysia so the items will be more expensive please count higher price for me like i5 3570k is about $250
I noticed a few minutes ago the sapphire 7870 XT is already a deleted item .
Perhaps there were only a limited number of chips available
Thermaltake are not a power supply you'd pick as first choice . Many of their units are junk You'need a 80+ bronze or better unit . 500 watts to run that pc.
No link to your RAM and my psychic mind powers are playing up . 1.5 volt OR LESS
Again the psychic mind powers cant help you with pricing in Malaysia
Can you recommend me some Power Supply around $70?(XFX is not selling in my country D:)
and what graphic should i get:??:
thanks and could you recommend me some 1.5v 2x4gb RAM?? (price around $50~$60
You should look for the best prices from local suppliers . Corsair venegeance RAM , or gSkill , or Kingston often have the exact same memory chips in them so it pays to find whats available and how much it costs . In general 1600 MHz , 1.5 volt and timings 9-9-9-24 [or lower]
The 7870 XT or LE are good cards and if they are available get one IMO , but if they are not then a 7870 games really well on a 1080p screen
Again with the power supply . Look for 80+ bronze or better rated units . 500 - 650 watts
For the Vengeance Low Profile — 8GB Dual Channel DDR3 Memory Kit (CML8GX3M2A1600C9R) what is low profile for?
For PSU should i get SilverStone 500w/600w 80+ or should i get CoolerMaster GX550 ?
i think i will change my casing to AEROCOOL CASING ATX X PREDATOR X1 USB3.0 (BLACK/RED) since its cheaper~
Do i need to add more fans just in case its too hot?
