First Gaming Build--$1200 max
G
Guest
Guest
Looking to build a gaming system in the $1000-1200 range. First attempted build, so simplicity is preferred. Will need 1 TB SATA HD. Have one now, but don't know if it will survive the transplant from the old system & thought best to double up. Have an HP w2338h 23" monitor.
APROXIMATE PURCHASE DATE: Now.
BUDGET RANGE: $1000-$1200 After Rebates
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: gaming, word processing, watching movies
PARTS NOT REQUIRED: Monitor.
PREFERRED WEBSITE(S) FOR PARTS; newegg COUNTRY OF ORIGIN: U.S.
PARTS PREFERENCES: by brand or type. Would prefer nvidia for the GPU but it's not a dealbreaker.
OVERCLOCKING: Maybe SLI OR CROSSFIRE: Maybe
MONITOR RESOLUTION: 1920x1080
ADDITIONAL COMMENTS: Will need a new OS & would appreciate any recommendations on that. Don't need to play every game at max levels, but want a set-up that won't be obsolete by this time next year. Thanks for any ideas.
Here is one...
CPU + Mobo + RAM
i7 + Gigabyte UD4P + 4GB DDR3 OCZ 1600MHZ
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.280597
CASE + PSU -
Antec 300 Illusion + Antec TP 650W
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.288424
1TB Seagate + WIN 7 Home Premium
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.282241
Graphics card - HD 5850(If you can get one...)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102857
DVD
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118030
CPU cooler -
http://www.newegg.com/Product/Product.aspx?Item=N82E16835887023
or Scythe Katana with the LGA 1156 socket retention kit...
Total - ~$1100 Not including shipping and rebates...
G
Guest
Guest
That all looks real good--exactly the sort of info I was looking for-thanks a ton. Why is the 5850 so tough to get? Also; is it so superior to comparable cards that it would be worth waiting a couple months to get one?
overshocks
1,204
25
Here's a build that I've done for another person a few days ago.
Note: this build has a monitor, you have one already so just never mind it..
I only used newegg, but you can use other sites if you can find the same parts for cheaper.
Or if you can find better combos at newegg
Here's an i5 750 build with new monitor, without O.S
>MOBO+RAM
30 dollar discount
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.289943
>Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197&cm_re=haf_922-_-11-119-197-_-Product
>CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215&cm_re=i5_750-_-19-115-215-_-Product
>Hard drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181&cm_re=spnpoint_f3-_-22-152-181-_-Product
>Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102857&cm_re=5850-_-14-102-857-_-Product
>Monitor
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236049
>Optical Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
>Heatsink
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
>Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
Total: $1,288.88 Before Rebate
This build gives you the ability to crossfire/sli in the future if new games are more demanding. You could add in another graphics card, the power supply is decent and could handle 2 graphics card.
@ SuperCollider It is because they are next-gen, currently have NO competition, and ATI dint expect this huge demand for these chips and had ordered only low quantity of these chips from the fabrication manufacturers...Or like overshocks said they made very few...
G
Guest
Guest
Okay-follow up question; If I get the set up above, would I be able to use my Nvidia 7800 gs in it until the 5850 is available? Or are they totally incompatible? Just from checking around, I don't have real high hopes for getting a 5850 anytime this year.
G
Guest
Guest
Okay-here is what I settled on & plan to order these components in the next couple days. Please advise of any compatibility issues or better options in a comparable price range. The stuff I have earmarked is right around the $1000 mark & I have allotted another couple hundred for RAM and cables, etc. This is my first attempted build so any ideas are appreciated. thanks.
Monitor
HP 23 inch (already purchased)
Video card
Sapphire HD5850 (already purchased)
Cd/DVD drive
Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
PSU
Cooler
OS/Hard Drive combo
Processor/Mobo combo
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.290305
Similar threads
