https://pcpartpicker.com/list/JMZs8Y
Above is what I have thus far based on recommendations, however I can't seem to find a cpu cooler that's compatible with the motherboard.
The mobo and case also have a slight issue with the front not having 3.0 usb ports, so I'm unsure if the case/mobo should be different. I know very little, but for the most part the components present seem very good. Surprisingly high end while managing to stay close to my budget (even including the monitor and keyboard.
But I would like to turn to the community for help/advice/suggestions. If there's anything that may need to be done for this build I would love to know.
I also have a microcenter available to me if that's of any importance, I only know that the CPU + Mobo deals are best there. Unsure if I should be getting all of my components there as I would prefer to obtain everything at once.
