First Homebuilt Computer Help
Oukranos
7
I've been doing some research and this seems to be the cost effective way to get a gaming computer i have around $450-$650 and would like to play games like dark souls/borderlands 2 on average setting if i can get the parts a local store that would be better any help would be appreciated
Approximate Purchase Date: Before Christmas
Budget Range:$450-$650 After Rebates/After Shipping
System Usage from Most to Least Important: Gaming
Are you buying a monitor: No
Parts to Upgrade: None building from scratch
Do you need to buy OS: No
Preferred Website(s) for Parts: Newegg.com/Bestbuy.com/Fryselectronics.com
Parts Preferences: None
Overclocking: Maybe
SLI or Crossfire: Yes
Your Monitor Resolution:1920x1080
Additional Comments: Dark Souls/Borderlands 2/DotA 2 other such newer games
And Most Importantly, Why Are You Upgrading: Current computer running games at low settings and having trouble doing so would like to run atleast average settings
CPU: Core i3-3220. $120
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116775
Mobo: AsRock H77 Pro4. $80
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157302
RAM: G.Skill Ares 8GB (2x4GB) 1600Mhz CL9 1.5v. $38
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231544
GPU: Sapphire Vapor-X HD7770. $120 ($15 rebate)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102993
PSU: XFX Core 550W, 80+ Bronze. $70 ($10 rebate)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
HDD: Seagate Barracuda 1TB 7200RPM. $70
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
Case: Zalman Z9+. $60
http://www.newegg.com/Product/Product.aspx?Item=N82E16811235027
Total (before rebates and shipping): $558
You have a fair bit of cash left, around $100. Where you want to put the cash is up to you. Good options I can see is a better case, an SSD, a CPU/mobo upgrade or a better GPU.
If your after longevity over a long time frame, then I advise the case upgrade, as that will last longer than any of the stuff inside it.
If your after longevity over a medium timeframe, then I advise the CPU mobo upgrade. Get a 3570k and a Z77 board. That means the rig is easily upgradable (can just throw any new GPU you want in without fear of bottlenecking).
If your after performance right now, upgrade the GPU to a 7850/660.
If your after blazing boot up times and general responsiveness in the rig, then get an SSD.
Yep, thats whats good about custom machines, its relatively easy to replace components in the rig.
Though of course make sure that your machine can handle any upgrades you think of beforehand. For instance, throwing in another graphics card for Crossfire/SLI isnt possible on this rig, the PSU is too small and the mobo doesn't support dual Crossfire/SLI adequately.
