First launch after AC power loss cause quick restart (POST FAIL?)
k2nder
15
Hi ho,
I just bought new pc:
CPU - ryzen 5 1600 (stock cooler)
MOTHERBOARD - asus prime b350 plus
RAM - https://www.morele.net/pamiec-g-skill-ri...rb-788194/ (g skill ripjaws V ddr4 3000 cl15)
GPU - zotac gtx 1080 amp!
PSU - seasonic focus gold 650
CASE - phanteks p400
HDD - iridium pro 240/hdd 750
WLAN - tl-wn881nd
everything works perfectly fine but when I try to run my pc after ac power loss it restart quickly once (looks like first POST fails) and then works perfectly fine until another ac power loss. I tried to reset cmos, change ram slots, change ram speeds, voltages downgrade bios from 3203 to 1002 and problem still appears. It looks like those ram's cause that reset.
My question is if this a real problem and if so what can I do?
It's probable that the reboot is a form of the system applying the settings for your ram(since it's an overclock) and thus the reboot after the AC power up. It's my assumption since most of your lingo has been...misused IMHO.
Regardless, see if removing the wireless card changes anything for you, if your friend's ram kit gives you a better experience and lastly let Asus know of your issue via email(and the seller you purchased the motherboard from). It's also probable that you may need to RMA the board.
That sounds ridiculous but that card removal actually fixed that issue...
Now it boots perfectly fine after ac loose...
I just don't get it...
Thanks rocktalkrock and especially you Lutfij for wasting your time to help me with that sordid issue and finally manage to point solution. I'd never guess that it can be wlan card...
One more time big thanks 😉
This is a family friendly site.
Mind your language.
Lutfij
And that's exactly what I'm planning to do ^^
