First pc build questions!
viperfuzz
48
Will be buying from PLE computers, premade.
Buying about christmas.
Build atm -
i5 4670k
Cooler master hyper TX3 Evo Cpu cooler
Asus Z-87M-Plus LGA1150 ATX mobo
Corsair 8gb DDR3 1600MHZ
Samsung 840 EVO 120gb SSD
Seagate Bara ST500DM002 1TB 7200RPM
EVgA Geforce 770 SC ACX cooler 2gb
Case Cooler master storm trooper
Corsair Hx 650v2 650w Gold...
Can this support my headset of a Corsair Vengeance 1500?
Can it support a keyboard of Corsair vengeance K70 (mxred)
And finally will it stay cool running the highest loads, skyrim on 2 screens? thanks!
Almost forgot, will it actually all fit xD
Yes all of it will work perfectly fine and will remain quiet BUT according to newegg the motherboard is uATX and the cooler master storm trooper isn't compatible with it. It wont fit in the case. Instead of that motherboard I highly recommend this motherboard -----> http://www.newegg.com/Product/Product.aspx?Item=N82E16813131981. If you have any more questions be sure to send me a message
