Build Advice First Pc build
Hello,
https://pcpartpicker.com/list/k6r4Yd
What do you think of this build? Are there any problems or recommendations? The only thing I am on the edge about is the Psu, but since I already have it i feel I should include it.
Thanks
That psu you've chosen isn't going to be enough for that gpu not to mention a 120 AIO is weak to say the least.
What country are you located, what is your budget and what is your monitor resolution?
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor ($448.98 @ Amazon)
CPU Cooler: *ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler ($29.99 @ Amazon)
Motherboard: *MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard ($168.00 @ Amazon)
Memory: *TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($88.99 @ Amazon)
Storage: *Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($89.97 @ B&H)
Video Card: *ASRock Phantom Gaming OC Radeon RX 7900 XTX 24 GB Video Card ($1290.82 @ Amazon)
Case: *Montech AIR 903 BASE ATX Mid Tower Case ($64.98 @ Newegg)
Power Supply: *be quiet! Pure Power 12 1000 W 80+ Gold Certified ATX Power Supply ($129.90 @ Amazon)
Total: $2311.63
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2025-02-13 15:37 EST-0500
If that is the same exact PSU, I would replace it. Those were not very good when they were new. You don't want your fancy new hardware to go up in smoke, by cheaping out on power supply. Frankly you have some overspending in areas. You can have a much nicer system for even less than that.
CPU: AMD Ryzen 7 9800X3D 4.7 GHz 8-Core Processor ($479.00 @ Amazon)
CPU Cooler: Montech HyperFlow ARGB 360 76.2 CFM Liquid CPU Cooler ($99.90 @ Amazon)
Motherboard: ASRock B850 LiveMixer WiFi ATX AM5 Motherboard ($189.99 @ Newegg)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($88.99 @ Amazon)
Storage: Western Digital WD_Black SN850X 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($84.99 @ Amazon)
Storage: Western Digital WD_Black SN850X 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($118.99 @ Amazon)
Video Card: ASRock Phantom Gaming OC Radeon RX 7900 XTX 24 GB Video Card ($1290.82 @ Amazon)
Case: Montech AIR 903 MAX ATX Mid Tower Case ($79.90 @ Amazon)
Power Supply: Enermax Revolution D.F. X 1200 W 80+ Gold Certified Fully Modular ATX Power Supply ($146.86 @ Amazon)
Total: $2579.44
Generated by PCPartPicker 2025-02-13 15:28 EST-0500
Reactions: Why_Me
This is how I would do it with several optimizations done to the builds above:
CPU: AMD Ryzen 7 9800X3D 4.7 GHz 8-Core Processor ($546.99 @ Amazon)
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler ($35.90 @ Amazon)
Motherboard: Gigabyte X870 GAMING WIFI6 ATX AM5 Motherboard ($194.99 @ Amazon)
Memory: Patriot Viper Venom 64 GB (2 x 32 GB) DDR5-6400 CL32 Memory ($144.99 @ Newegg)
Storage: Inland Performance Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($74.98 @ Amazon)
Storage: Crucial P3 Plus 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($219.99 @ Amazon)
Video Card: Sapphire NITRO+ Radeon RX 7900 XTX 24 GB Video Card ($1029.99 @ Newegg)
Case: Lian Li Lancool 207 ATX Mid Tower Case ($79.98 @ Amazon)
Power Supply: Thermaltake Toughpower GF3 TT Premium 1200 W 80+ Gold Certified Fully Modular ATX Power Supply ($146.99 @ Amazon)
Total: $2474.80
Generated by PCPartPicker 2025-02-14 13:13 EST-0500
