First step to liquid cooling
Page 4 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
Captain_Hindsight
64
Hi guys,
It has been a few months since I upgraded my CPU+Mobo and now I'm thinking about treating my CPU (and my ears) with a water cooling kit.
I have set my eyes on the XSPC RayStorm 750 EX240.
http://www.xs-pc.com/watercooling-kits/raystorm-750-ex240-watercooling-kit
Secondly, because my current case can't handle a 240mm rad, I'm thinking of switching to a NZXT Phantom 530
http://www.nzxt.com/product/detail/134-phantom-530.html
Sadly there is no easy cooling solution for my GPU (as it is a non reference design). Therefore I will just do a CPU cooling loop, and when I feel like upgrading my GPU, I'll expand the loop with a 120 or 240 rad and a GPU water block
As I am totally new at this, I would like to hear your opinions/advice on this. Also, I couldn't find a comparison between the raystorm 240 and the raystorm 280 rad - any advice?
Thanks!
Ninja edit: Distilled water vs. pre mixed coolant - Is there any strong argument for one or another?
My Specs:
Mobo Asrock Z77 Extreme 4
CPU Intel i5 3570k OC @ 4.2 ghz
CPU cooler Thermaltake Contac 39
RAM Corsair Vengeance 2 x 4GB DDR3-1600 CL9 (OC to 1866)
GPU MSI R9 270 Gaming (GPU OC to 1110 Mhz)
PSU BE QUIET! 530 Watt 80Plus Bronze
CASE Silverstone PS06 (Positive Airflow 3x120mm 1x180mm)
Edit: only one after-market CPU Cooler :)
Welcome to the world of overclocking. Hopefully your transition from air to water will be easy provided you get the steps right.
Regarding your inquiry:
http://www.tomshardware.com/forum/277130-29-read-first-watercooling-sticky#3718886
There's a trend for people shifting over to dyes and coolants, if you are hell bent on going that route, you can look into Mayhems pastel/dyes. Mind you dyes are dyes because they stain items and in this case it'll be your tubing. Certain ranges of Mayhems are meant for events or shows and are not intended for long periods of use.
The 240 rad is basically a 2x120 rad whereas the 280 rad is a 2x140...
I did a load test with the measuring device, and I don't know what to think of the result :/
http://imgur.com/a/7Bzdc
while idle, it displays about 60W consumption
And in full load with the D5 pump on 5/5 and all fans on 12V + 3 x prime95 and 2 x Kombustor, it peaked at 350W.
First of all: Is this a reliable test?
From what I gather, my P/S has a max of 530x0.8=424W - what I think means I use a max 82.5% of my P/S.
Should I still go for a 750W P/S?
Well it appears the power supply is not being overloaded, sometimes it could just be on the verge of failure?
So what happened with reinstalling the GPU drivers?
