[SOLVED] First Time Build: Are These Parts Good Together?
May 26, 2020
Okay, so I've been researching parts for a while now, and I think that this is my best bang-for-your-buck rig. What do you think? I want something good for gaming, not over-the-top though, and I really like RGB (I know!).
AMD Ryzen 5 3600
MSI B450M PRO-VDH MAX m-ATX AM4 Motherboard
ASUS GeForce GTX 1650 SUPER 4GB TUF GAMING OC
Corsair Vengeance LPX 16Gb DDR4-3000
WD Black SN750 NVMe SSD M.2 PCI-E x4 500GB SSD
Seagate Barracuda 2TB HDD
Thermaltake Commander C31 TG ARGB
V550 Gold Semi-Fanless Modular 80+ Gold Power Supply, 550W
Would you say these are solid parts, or should I swap them out for another product similarly priced?
Total: $1150
price is in CAD (USD: $833)
AMD Ryzen 5 3600
Corsair Vengeance LPX 16Gb DDR4-3200
Total: $1150
Be sure to check on memory compatibility, if that set...
AMD Ryzen 5 3600
Total: $1150
Be sure to check on memory compatibility, if that set is CMK16GX4M2B3200C16, I don't see it on the QVL for that board with a Matisse CPU on the MSI support site HERE. Click on comparability on the left and select the button memory by RX-3X00 (Matisse).
Reactions: tbnrtianna
Whoops, my bad! I just fixed it and picked the DDR4-3000 of the same kind. Thank you so much!
