First time build - Does GA-Z77M-D3H-MVP work with xeon e3-1230v2
The E3 XEONs are designed more for a mid-range workstation. You can use them with most any 1155 motherboard, and they support regular DDR3 RAM. The E5 series are designed for server components and ECC RAM, and well out of this price range. I think since the OP listed his priorities as "photo/video editing, some 3d CAD, and minor gaming", the E3-1230 V2 addresses his primary needs the best.
So last question will a integrated GPU work with a Dedicated GPU to increase performance or is it only one or the other.
Thanks to all who helped It looks like i will be going with this build.. Unless there are any other suggestions..
So this build looks Good
CPU: Intel Xeon E3-1230 V2 3.3GHz Quad-Core Processor ($234.98 @ SuperBiiz)
CPU Cooler: Noctua NH-L12 37.8 CFM CPU Cooler ($49.99 @ NCIX US)
Motherboard: Gigabyte GA-Z77M-D3H-MVP Micro ATX LGA1155 Motherboard ($89.99 @ Newegg)
Memory: Crucial Ballistix Sport 16GB (2 x 8GB) DDR3-1600 Memory ($111.68 @ Amazon)
Storage: Crucial V4 256GB 2.5" Solid State Disk ($164.98 @ SuperBiiz)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($96.88 @ Amazon)
Video Card: Asus GeForce GTX 660 2GB Video Card ($191.98 @ SuperBiiz)
Case: Cooler Master Elite 343 Mini Tower Computer Case (46.39 @ Amazon)
Case Fan: Gelid Solutions FN-PX09-20 37.9 CFM 92mm Fan ($8.98 @ Outlet PC)
Power Supply: SeaSonic 520W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($79.98 @ SuperBiiz)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($17.98 @ Outlet PC)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($89.94 @ Outlet PC)
Total: $1183.75
AxlFone,
Regarding Xeons > 1> I only looked at the Newegg listing for the Gigabyte board which did not mention Xeon compatibility.
2> My comment was not to suggest that Xeons are inherently slower. To the contrary, if you look at the Passmark CPU Benchmark chart in order of ranking >
http://www.cpubenchmark.net/cpu_list.php
> 8 of the top 10 and 15 of the top 20 CPU's in terms of sheer computational power are Xeons.
The emphasis on accuracy and reliability means a Xeon / ECC/ Quadro in combination is specialized for precision and reliability for workstation applications will be more costly and not create high frame rates in most games. Oftentimes, Xeons are identical to the same level i3, i5, i7 but are locked for overclocking, delete the integrated graphics, and have double precision enabled, 10-bit color, and ECC RAM support. One of the main advantages of Xeons is that some can be used in multiples- there are boards that support 8X Xeon E7 (10-core / 20 thread) CPU's (these can cost $4,500 each), 1,024GB of RAM and with each CPU comes more PCIe slots for which items like several Tesla K20 co-processors may be plugged.
ECC RAM is slowed a bit by correcting errors and Quadros have special drivers that support very high anti-aliasing (up to 128x) which takes a lot of calculations and means each frame is rendered more fully- and is slower. For contrast, Sketchup runs at a standard of 4X. Quadro cards are also often running slightly lower clock rates -and at less power to keep them reliable. In fact a Xeon, because of the computational power in combination with a GTX would be pairing a powerful CPU with a frame rate-oriented GPU with a lot of CUDA cores- probably a very good combination. As mentioned, the ECC RAM is not conducive to gaming, but Xeons will run on non-ECC.
In summary, Xeons can be faster than consumer / gaming CPU's, but even quite a ways from the top end they can be very expensive (the 8-core, 3.2GHz 2687W is $1,900) and their use with other components like ECC and Quadros mean that they will not seem like "good buys" if their qualities are not utilized. I would say that Adobe CS, Autodesk, most 3D modelling, rendering and so on can greatly benefit from the Xeon / ECC / Quadro combination. But as mentioned earlier, whether a user has expectations of quality that require these components is a question of degree. Using a Xeon/ ECC machine, I tried to get away with a GTX 285, and it worked up to a point, after which I had to change it for a Quadro FX 4800. Stated another way, I thought I could use a $350 card (new) that read as a great buy- 512-bit and 240 CUDA cores and high 3D benchmarks, but to avoid bizarre shadows, artifacts, limited anti-aliasing, rendering crashes, and missing viewports, I ended up with a $1,200 card (new) that is 384-bit, 192 cores, and 3D scores 30% lower- but runs quite a bit cooler- 150W as compared to the GTX 205W- and produces fantastic-looking results and works perfectly on 16 hour CAD slogs.
As compters become more capable, they are also becoming more specialized and the difference between content makers and content consumer systems becomes a more difficult equation for the buyer / builder.
Cheers,
BambiBoom
[Dell Precision T5400 > 2X Xeon 4-core X5460 @ 3.16GHz, 16GB DDR2-667, Quadro FX 4800, WD RE4 / Segt Brcda > Windows 7 Ultimate 64 > AutoCad, Revit, Solidworks, Adobe CS MC, Corel Technical Designer, Sketchup Pro, WP Office, MS Office]
[/quotemsg]
The Primary use is going to to be photo/video editing, some 3d CAD, and minor gaming...
I am new to this build your own idea, I looked on gigabytes sight at the motherboard CPU Support List(http://www.gigabyte.us/products/product-page.aspx?pid=4328#) and it showed "Intel Xeon E3-1230v2" on its list. Does this mean that it is supported? I want this build to be relatively straight forward since it is my first.
I initially had the i7 3770k for a CPU, but I was steered towards the xeon because i was not going to OC and because it was <$100 than the i7 for the same performance.
Another question, if i used non ECC RAM Would the Performance be comparable to the i7 3770k still or would it drop off? [/quotemsg]
nodrog01,
The motherboard > Yes, the Gigabyte GA-Z77M-D3H-MVP does support the Xeon E3. I had only made a quick look at the specifications on the Newegg site- which did not mention Xeon support. If fact, that board seems to me to be a really good choice in terms of features.
However, I have some concern that the Gigabyte board, while inexpensive and full -featured may be giving up too much in terms of performance. There is unfortunately only one baseline for this board on Passmark Performance Test and it's using an i5-3570K, Intel 4000 integrated graphics and a mech'l HD, making a rating of only 1390, due to the integrated graphics and slow disk. The CPU score was 5677. This is not fantastic performance from the i5- systems with that CU score up to 7000+. For comparison, so as to try and isolate the board performance, an i5-3570K / Intel 4000 / SSD system scored 2583 using an MSI Z77A-GD65 board. The GPU score was 7477. This may sound like a useless comparison as the CPU and GPU is not the same as on your list, but it shows that the Gigabyte board was scoring 5677 out of the same CPU / Integrated Graphics/ Z77 chipset from which the MSI board extracted 7477. The MSI also supports the Xeon 1240v2, but costs $165 instead of $90, a 30% performance increase for an 80% increase in price. While the MSI had the best performance from the i5/IG, I'm not recommending the MSI necessarily- and it shows the good cost/performance ratio of the Gigabyte, but am wondering if the budget would allow consideration of a board that would make better use of the Xeon. Perhaps others here will know a good one in this context. Just to be sure of the choice,..
I watched a Youtube video showing the Cooler Master Elite 343 case and it seems to have a lot of drive bays- a better situation than I thought, but still may be a bit tight.
Cheers,
BambiBoom
nodrog01,
Cheers,
BambiBoom
[/quotemsg]
So i guess the question is, is there a better (Micro ATX)board that will fit the case and other components. The MSI you mentioned appears to be an ATX Board..
