Hi there,
So I'm going to attempt to build a PC for the first time and have some questions about the components I plan on buying. I'm looking to build a mid-range PC that can handle new games but doesn't need maxed out graphics. After some reading I put together the below list of components and have some questions.
Is there any compatibility issues or any other concerns I should consider with these parts?
If there is any recommendations on getting the price down that would be great as well, I may not need exactly what think I need.
Would looking at used parts be risky?
What’s the degree of difficulty for putting together a system like this, it doesn’t seem too bad but I’ve never done it.
Picking the right parts can be kind of intimidating as a first timer, so any feedback would be great.
CPU: Intel Core i5-7500 LGA 1151 7th Gen Core Desktop Processor (BX80677I57500)
Motherboard: ASRock B250 Pro4 LGA 1151 Intel B250 HDMI SATA 6Gb/s USB 3.0 ATX Motherboards
Memory: Crucial 8GB Kit (4GBx2) DDR4 2133 MT/s (PC4-17000) SR x8 Unbuffered DIMM 288-Pin Memory - CT2K4G4DFS8213
Storage: Crucial MX500 500GB 3D NAND SATA 2.5 Inch Internal SSD - CT500MX500SSD1(Z)
Video Card: Gigabyte Geforce GTX 1050 2GB GDDR5 128 Bit PCI-E Graphic Card (GV-N1050OC-2GD)
Case: Corsair Carbide Series 200R Compact ATX Case
Power supply: Corsair CX Series 750 Watt (2017) 80 Plus Bronze Certified Non-Modular Power Supply (CP-9020123-NA)
