First time building pc(Need advice)
zero1995
4
Gigabyte Z77X-D3H
Intel i7 3770
Kingston DR3 PC1600 8GB
Western Digital Blue 7200r 1TB
Intel 2.5" 330 Sandisk 60GB
nVIDIA GeForce GTX 550ti 3GB
Corsair GS600 Bronze Gaming 600Watts
Cooler Master RC 430-KWN1 430 Black
Liteon 24x Sata Box
Samsung 23" LED Monitor
Windows Home Premium 64bit
Logitech USB Keyboard K120
dalmvern
673
1. What is this machine going to be used for.
2. Get a bigger SSD than 60GB.
3. Unless you are planning to SLi, drop your PSU to 500W. If you are planning to SLi, dont, get a more powerful single card.
zero1995
4
For gaming, but it's mid - mid high level gaming
What's a cheaper ssd but with higher gb recommended?
What's sli?(sry, Noobie here..)
freshbakd
235
My only advice would be to step down to an i5 and spend the saved few dollars on a step up on graphics card.The ssd is small could just use the mechanical until you save for a decent amount of fast storage. I know you will hate life when you have start uninstalling to download new games.
and sli is using multiple graphics cards on one machine(take his advice unless your just trying to take it to the next level like multi flagship card$$$$)
dalmvern
673
If it is a gaming machine, drop the processor to an i5-3570. That will save you plenty of money to get a better SSD, I would say minimum of 120GB. I made the mistake of getting a 60GB SSD a few years ago for a budget machine and you would be surprised how much slower it was as the SSD began reaching capacity (which it does quickly wich such a small drive.)
Also, SLi is Nvidia's name for taking two compatible graphics cards and bridging them together to boost performance. ATI calls it Crossfire. On the topic of graphics cards, you may want to consider an ATI graphics card. They are typically cheaper for similar performance, but its really personal preference.
zero1995
4
Advice on graphics card? Performance to price wise?
I am not very well-versed in which graphics card is good...
dalmvern
673
Your best bet for graphics card is to calculate your cost with the changes we have proposed and see how much you have left in your budget. Then take a look at this article, see which card falls into your price range and go with it.
http://www.tomshardware.com/reviews/gaming-graphics-card-review,3107.html
dalmvern
673
As far as best performance/price, I would probably recommend the Radeon HD 7850 at around $200 since you arent expecting to max out everything. With that card though I would probably also recommend that you keep your 600W PSU...they list 500W as a minimum and I always like to have a little more headroom than they recommend, especially when it comes to the power supply.
