First time installation - need advice
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
I'm replacing my old HD with a new WD 250 Gb Hard drive
before, I've only had a 40 Gb with Win2k Pro
Now, I'm going to install WinXP Pro for the first time and need some advice.
I had heard, in the past, with large hard drives, that I should create a
partition with just the OS on it - then install everything else on a second
(or other) partition.
The flaw in this, as I can see it, is that, when you install an
application - the DLLs get installed in the System32 directory anyway - so
no matter what, if something happens to the OS partition - it all gets hosed
anyway.
So - - I'm seeking advice on the most efficient way to set this system
up --- (for once, I'm asking BEFORE I'm actually doing it)
Any ideas here?
I like to have several partitions because I can install the
OS and applications to C: and use D:,E:,F: for My
Documents, downloaded files, which means that you can format
C: with the XP CD and reinstall clean and all your data,
emails and downloaded program, and video/music is still
safe. You can reinstall quickly.
Having two or more physical drives is better, but cost more
money. Partitions are a nice compromise. Set your CDROM/RW
DVD as drive L: or M: so you don't have issues with paths
and renaming. When you network, drives will be mapped as
W:.X:, Y:
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
"Elmo Watson" <sputnik75043@nospam.Yahoo.com> wrote in
message news:efFHPt$1EHA.3120@TK2MSFTNGP12.phx.gbl...
need some advice.
should create a
else on a second
install an
it all gets hosed
| anyway.
this system
| Any ideas here?
"Windows XP Clean Install (Interactive Setup)"
http://www.winsupersite.com/showcase/windowsxp_sg_clean.asp
Ted Zieglar
"Elmo Watson" <sputnik75043@nospam.Yahoo.com> wrote in message
> advice.
> second
> hosed
> anyway.
> Any ideas here?
That's a really great reference, and I'll definintely use it when I
install - -
however it doesn't address whether it's best to create separate partitions
on a clean install, or whether to just keep one - - I probably didn't make
myself very clear - what I need advice on, is whether or not to install
multiple partitions - the pros and cons
does it really matter at all?
"Ted Zieglar" <teddyz@notmail.com> wrote in message
news:elLZv7$1EHA.3500@TK2MSFTNGP09.phx.gbl...
> Ted Zieglar
> > advice.
> > second
so
> > hosed
> > anyway.
> > Any ideas here?
Windows XP works very well in one partition. Whether or not to repartition
your hard disk is a matter of convenience, not performance. You may find it
convenient to place your data files on a separate partition.
Ted Zieglar
news:e%23kcYJA2EHA.2016@TK2MSFTNGP15.phx.gbl...
> install - -
>> Ted Zieglar
>> > advice.
>> > a
>> > second
> so
>> > hosed
>> > anyway.
>> > Any ideas here?
I will (and presently, do) have a lot of apps - so, even a format/reinstall
would take a long time, either way - - and I'm fairly sure 95% (or more) of
the apps I use bloat the registry a little/lot.
I never thought of the fact that you can make My Documents go to another
drive - - I just thought it was integrated into the system some way - - so
if I move the whole My Documents folder from where it is (documents and
settings/etc), to another dirve - and then just change the path to that
location in the desktop icon's path - that's all there is to it?
"Jim Macklin" <p51mustang[threeX12]@xxxhotmail.calm> wrote in message
news:Oxbb7NA2EHA.804@TK2MSFTNGP12.phx.gbl...
> W:.X:, Y:
> need some advice.
> should create a
> else on a second
> install an
> it all gets hosed
> | anyway.
> this system
> | Any ideas here?
In XP, click START, right click on My Documents, select
properties and you'll find a "move" button. You still need
to change the "store folder" for Outlook Express/Outlook.
It makes things a lot more secure in case of a system crash.
message news:u$s%23aHC2EHA.2568@TK2MSFTNGP10.phx.gbl...
format/reinstall
95% (or more) of
go to another
some way - - so
(documents and
path to that
to it?
in message
the
format
more
CDROM/RW
paths
as
| > W:.X:, Y:
drive
and
| > need some advice.
I
| > should create a
everything
| > else on a second
| > install an
partition -
| > it all gets hosed
| > | anyway.
set
| > this system
it)
| > | Any ideas here?
"I'm fairly sure 95% (or more) of the apps I use bloat the registry a
little/lot."
Funny, none of my applications "bloat" the registry. Guess we use entirely
different applications.
Ted Zieglar
> of
>> W:.X:, Y:
>> need some advice.
>> should create a
>> else on a second
>> install an
>> it all gets hosed
>> | anyway.
>> this system
>> | Any ideas here?
Unless you run the install through a program that logs all install data, you
will never know! (-:
Example: CDCreator 6 logs, among others, over 600 registry entries. Doesn't
matter which drive/partition you install it to. The entries are still there
(of course).
And, I won't even mention a full install of any Office suit!
Talk about registry bloat.
Regards:
Richard Urban
aka Crusty (-: Old B@stard 🙂
news:eoS32NC2EHA.3840@tk2msftngp13.phx.gbl...
> little/lot."
> Ted Zieglar
>>format/reinstall
>> of
>> so
>>> W:.X:, Y:
>>> need some advice.
>>> should create a
>>> else on a second
>>> install an
>>> it all gets hosed
>>> | anyway.
>>> this system
>>> | Any ideas here?
How do you know it's "bloat"?
Why not provide a list to Roxio of which keys could be safely eliminated
from their software so as to eliminate "bloat". You seem to know a lot about
the subject.
Ted Zieglar
"Richard Urban" <richardurbanREMOVETHIS@hotmail.com> wrote in message
news:ePIoUYC2EHA.3576@TK2MSFTNGP12.phx.gbl...
> you will never know! (-:
> Doesn't matter which drive/partition you install it to. The entries are
> still there (of course).
> Regards:
> Richard Urban
>> little/lot."
>> entirely different applications.
>> Ted Zieglar
>>>format/reinstall
>>> of
>>> so
>>>> W:.X:, Y:
>>>> need some advice.
>>>> should create a
>>>> else on a second
>>>> install an
>>>> it all gets hosed
>>>> | anyway.
>>>> this system
>>>> | Any ideas here?
> advice.
> create a partition with just the OS on it - then install everything
> else on a second (or other) partition.
> - so no matter what, if something happens to the OS partition - it
> all gets hosed anyway.
> Any ideas here?
When you have the OS on it's own partition, it is easier to create an image
backup of the OS partition and then a simple backup of the applications
folder on the other partition. If the OS partition gets hosed, you can
restore an image and all the applications and their settings, data etc. are
intact. You only need to update the image when you make a change to the OS.
Keeping the OS partition to the size of one or two DVD's makes it much
quicker than 4 or more DVD's for a single unpartitioned hard drive.
I usually have a XP partition of 8 to 10 gigs and depending on what you use
your computer for determines the way the space is divided up.
I would allow at least 20 gig for the application data partition and if I
were downloading large video files, make the rest one big partition.
There are many opinions on partitions and it is really a matter of how you
use your computer that dictates the configuration. I do think having a
manageable partition for the OS is a better arrangement than one big
partition, but that is my opinion and what works for me.
Michael Stevens MS-MVP XP
xpnews@bogusmichaelstevenstech.com
http://michaelstevenstech.com
For a better newsgroup experience. Setup a newsreader.
http://michaelstevenstech.com/outlookexpressnewreader.htm
On Wed, 1 Dec 2004 18:09:46 -0600, "Jim Macklin"
>W:.X:, Y:
I'm in a similar situation in that I am building a new system with a
Seagate 200GB 7200rpm drive. I also have a Maxtor 40GB 5400rpm drive
from my old system that I could use, or not. The Maxtor is 3yrs old,
and has run more or less constantly the whole time.
Would you lean towards putting the system on a partition of the new
Seagate without using the Maxtor, or using the Maxtor for system and
apps and keeping the Seagate for data.
How much do you think performance would be affected by having the
system on the slower Maxtor?
Thanks,
Mike
