Hello everyone
I have some newbie questions to ask about buying and installing fans into my chassis. I would like to improve the cooling system inside my case since i am currently having some heat issues with it, i do fear the worse when summer comes 🙁
I think i do have only one of the fan with blue LED installed on the front it's located at HDD/SSD area. I'm planning on buying at least 3 fans and install them into my chassis to improve the cooling quality of it.
Here's what i have, a mid tower chassis made by Cooler Master which is Elite 431 Plus and i have a Asrock Z77 PRO3 Motherboard.
I already checked the official site for the specs of my chassis and my motherboard, here are the sites http://www.asrock.com/mb/intel/z77%20pro3/ and http://www.coolermaster.com/case/mid-tower/elite-431-plus/
My CoolerMaster Elite 431 Plus chassis maximum amount of fans can be installed are 5 fans.
My Motherboard specs
- 2 x CPU Fan connectors (1x 4-pin CPU_FAN1 and 1x 3-pin CPU_FAN2)
- 2 x Chassis Fan connectors (1x 4-pin CHA_FAN1 and 1x 3-pin CHA_FAN2)
1x 4-PIN CPU_FAN1 USED BY INTEL STOCK COOLER 1x 3-PIN CPU_FAN2 UNUSED
1x 4-PIN CHA_FAN1 UNUSED, 1x 3-PIN CHA_FAN2 UNUSED
1x Power Fan connector (3-pin) PWR_FAN 1 UNUSED
The fans connectors are currently not in used are 3-PIN CPU_FAN 2, 4-PIN CHA_FAN1, 3-PIN CHA_FAN2 and lastly 3-PIN PWR_FAN1.
I do believe my CPU stock cooler made by Intel has already taken the 4-pin CPU_FAN1 connector. and my blue LED 120mm? fan on the front is plugged and powered by my PSU? I'm not sure myself since my chassis connectors are not in used. Anyway, i just looked inside my case again and i found out that my 4-PIN CHA_FAN1 and 3-PIN CHA_FAN2, CPU_FAN2 and PWR_FAN1 are all unused.
Okay here are my questions
(Question 1)
I want to get 3x of 120mm fans with 3-PIN and i wonder will it work if i plugged 1 of my 3-PIN 120mm fan to my 4-PIN CHA_FAN1 connector? Will there be any problems with it? or should i plug in my 3-PIN 120mm fan to 3-PIN CPU_FAN2 connector instead? How about the 3-PIN PWR_FAN1? will it work if i plug in one of my 3-PIN 120mm fan into it?
OR should i get 1x 120mm fan with 4PIN, and 2x 120mm fans with 3-PIN?
I'm planning on installing 2x 120mm fans on top, and 1x 120mm on the rear, and having all of those 3 fans blowing out the heated air.
(Question 2)
Do i need to get screws and nuts to install the fans or they are included with the fans when you purchase them?
I really do need your help on this
since this is probably my first time on installing new fans into my system so i need all the information and help that i can get
And please do feel free to drop recommandations on which brand of 120mm fans should i buy,
My budget is probably somewhere to 50 to 100 USD i don't mind raising my budget if quality ones are above the budget price.
(Question 1)
(Question 2)
