The computer says new hardware found it install succesfully but when I click to view my files it displays a massage "Please insert a disk into drive G" it is a 8 gigabite Dixon flash drive. Please I need my files..
Embarrassing it is, I've got the same problem with my Kingmax 4Gb pendrive. ><
However after reasonable amount of researching I've came across a few posts stating that this problem could be solved by low level formatting it...
there are a few tools which can low level format a Flash drive, one of which is...
I suggest that you try it out... unfortunately It didn't work out for me... 🙁
the tool did not recognize my usb flash drive...
Just let me know if it works for you.....
