flash stick not working
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I have a Dell Dimension 8300 running XP pro.
When I try to plug in a Dell flash stick that came with the computer,
the front USB ports do not recognise the stick but the back USB ports do.
It is kind of a pain to have to reach around to the back of the computer
to use the flash stick. The stick works on other computers but not mine.
I also tried using a USB hub in order to bring a port to the front of
the computer but that does not work either.
Any suggestions?
"William Kossack" <kossackw@njc.org> wrote in message
news:10vd8c81cm39bb6@corp.supernews.com...
> When I try to plug in a Dell flash stick that came with the computer, the
> I also tried using a USB hub in order to bring a port to the front of the
> Any suggestions?
William,
Do other devices work on the front ports?
Stew
Yes other devices work on the front port.
When I open up my computer the stick does not appear as a device and
windows explorer does not see it
yet the flash stick works on the back ports and other computers
>>Any suggestions?
>William,
>Stew
figured it out
needed to map another drive
the usb was taking over the maping or trying to use a network drive letter
> computer to use the flash stick. The stick works on other computers
> but not mine.
> Any suggestions?
William Kossack <kossackw@njc.org> wrote in news:10vd8c81cm39bb6
@corp.supernews.com:
> Any suggestions?
I can't explain why you are having the difficulty. But for my desktops
without front USB ports, I use a USB "extension cord."
Tom McCune
http://www.McCune.cc
