Hey folks,
Quick question that I can't seem to find any clear answer to using Google.
My little home office room receives a pretty slow connection from the router, about 15-20% of the 1000mb/s connection that I have.
In order to try to remedy this, I bought a flat Cat8 cable, and threaded it through a few gaps/walls through to my office. In order to avoid having to cut out large holes, I cut off the RJ45 connector on one end, intending to fit a new one once the cable had been threaded. Before I did this, I tested the cable, and it was fine, I got the full 1000mb/s through it. The problem I have now, is that no matter what I try, I can't seem to get the thing to connect once I add a new RJ45 connector. There is a pretty high chance that I've messed it up, as the Cat8 wires are very small and fiddly. I have some passthrough connectors arriving soon, which should be easier to see and check that the wire order is correct. However, one thing I wanted to check is whether a standard RJ45 connector is suitable for Cat8? I can't see any difference, and the connectors/wire colours all look the same as Cat5/6/7 etc. It's just the wires that seem a bit more delicate, so I'm not sure if that needs a specific connector to ensure they "connect".
I hope that makes sense?
Cheers, Ori
Cheers, Ori
