How To
Fortnite Battle Royale - Damage Trap Guide
Damage Trap is a great item if you know how to and when to utilise it. It can not only get you some kills but can save you from shady situations where you are being chased by a stronger enemy.
Just use the tips mentioned below and you will be able to use it in an optimal way:
Use Loot to Lure Them:
The most common and proven way to trap enemies is to lure them with loot. The greedier a player is, the more chances of him getting trapped. And in this game, everyone is greedy to some extent. So what you need to do is just to place the loot near the window where the player can see it from a distance. Make sure to close the door so they don’t suspect someone’s presence. Now just wait and sooner or later you will get the kill.
Make Them Chase You:
One of the best tactics for using a trap in a way that does not seem suspicious at all is first to place a trap inside a building and then go outside. Now Shoot an enemy one or two times and then run inside. Based on the aggressive behaviour of players, your enemy will chase you inside and when he reaches the room you have placed the trap in, they will be trapped. Just make sure to remember the room in which you have placed the trap because if you forget, the tables can turn as well.
Beware of Traps as Well:
It is all good until you are using traps but it gets worse if someone else is also using one. Players in Fortnite Battle Royale are usually very aggressive and this is the primary reason that they become the victims of traps. If you are entering in a building where you think an enemy might be present or if you see rare loot sitting inside a building or at some shady place, always make sure to check the doorways and ceilings as people usually place traps there.
Save it for the End:
Many players utilise the damaged trap when they don’t even need it. They use it just for fun and then later on in the game, when they really need a damage trap, they realise they don’t have one. The best thing to do is to wait until you really need a damage trap for your strategy. It is suggested that you save your damage trap for the last and in the final circle when players are so close to each other, build yourself a fort and place the trap inside it in a way that stays hidden from them and when they come inside your fort, they get trapped.
These are all the tips related to traps that can help you get some action. Just make sure to place them someplace where other players don’t see them or else they can destroy the trap.
