Wood is the most used structure in the Fortnite Battle Royale and there are various reasons behind it.
If you use wood as well then you need to take a look at the tips given below:
What Gives the Most Wood?
When it comes to gathering material in Fortnite Battle Royale, then every player wants to gather materials as quickly as they can so that they can carry on with other things like collecting loot, building bases or engaging in combats. This is why, knowing which structure gives the most wood is necessary. So if we talk about the most giving structures, then Big and Small trees are the ones that give the most wood. Walls and Fence will provide you with a decent amount of wood but it will not be as much as the trees. Each hit to the tree can give you anywhere from 20 to 50 wood or maybe more. Also, it is a great way to gather wood on the go as you will be seeing a lot of trees on your
way to the circle.
Collect Wood Fast:
When it comes to collecting the wood, you can literally collect at the speed of 2x. This is true and a lot of players do that. It is not a hack as this feature is present in the game. What you need to do is when you hit a big or a small tree, you will see blue circle near the place you hit. That circle is called as critical point. What you need to do is to hit that critical point and it will double the amount of material you are getting from that structure. It is really effective way to collect the material faster.
Don’t Break Trees:
One thing that you need to keep in mind when you are collecting the wood from the trees is that you should not extract the trees completely. Instead, leave them when they have a very low health remaining. This is because if you extract the tree entirely, it will make the tree disappear that will be followed by an animation making the tree disappear. This can be seen by nearby enemies as well. And that will let them know of your position. So when you are collecting from trees, it is best to leave them when they reach the end of their health.
Use for Defense during the Combat:
The best thing about the Wood is that it spawns with the most health and that is 100. This health is even higher than the metal or the brick. Also, wooden structures are built quicker than the metallic or stone structure. This is the main reason that you should use wood if you are in a combat and want to build something for your defense or to get a height advantage as the wood will not break easily.
These are all the important tips related to wood. Make sure to note these tips and use them next time you are playing the Fortnite Battle Royale.
way to the circle.
Collect Wood Fast:
Don’t Break Trees:
