I have had four annoying things happen to my Windows 10 computer all at the same time and I cannot get them corrected:
All of these things happened on the same day. My wife was the user at the time this started and there were no changes made to the hardware/software, etc.
I have tried a LOT of remedies to no avail. So far I have:
I have run out of things to try. Can any of you suggest anything else that I could do short of a full install?
I thank you for any advice that you can give......
- The Cortana search box at the bottom left of the screen no longer works.
- The FIRST time I try to use the start menu is opens but it grayed out and unusable. I click on the desktop and back on the start button and then the menu is fine.
- MS Edge opens but then quickly closes before it loads anything.
- MS Office 2016 apps will not open.
- Scanned with MalwareBytes.
- Scanned with Defender, AVG, F-Prot, Kaspersky and none of these detected any viruses.
- Ran SFC /scannow which says that it found corrupted file but could not repair/replace them.
- Did disk diagnostics with no errors found.
- Restored the disk from my backup using Acronis 2019.
- Reset all the MS Edge settings using the add/remove menu.
- Booted to the install disk and ran sfc /scannow and got the same error message as before: found corrupted files but could not repair/replace.
- Ran Windows update to confirm that I have all of the latest updates.
