fps drop problem when playing games
geiro
8
hello my rig is : AMD FX 8350 - DUAL CHANNEL 16GB RAM - 970A-DS3P motherboard - 3gb windforce GTX 1060 2xOC - 223GB SSD OCZ-TRION100 - 2TB SeaGate - and i have a water cooler seidon 120v V2 .. and my problem is that when im playing a game like GTA 5 fallout 4 Tom Clancys raimbow six siege i am playing fine with normal fps and suddendly my fps drops to like 10 - 20 fps sometimes for a minute sometimes 5 seconds and when it happend's my cpu is automaticly using lower cpu usage in the game im playing and my cpu wont go over 45° like its locked there and if it's stays to long in 45° the fps drop will suddenly come and then the cpu will like lower to 36° and fps go up again and this happends again after like 15min's .... only happends in heavy games ... help
The cpu si not damaged, the problem si the cooler, AMD is renown to need the motehrboard VRMs to be cooler actively. When you mounted as water cooler there si no air blowing towards the VRMs. When the VRMs overheat the cpu becaomes unstable or lowering frequemcy. Try to put a small fan to blow towards motehrbaord VRMs adn see if it helps. This is the most common...
Your system setup seems to be fine.
Have you installed the latest drivers for everything you have?
Maybe the problem is that the game isn't actually utilizing all the CPU and GPU Power.
It's strange i must say.
Update your drivers and tell me if there are any differences.
Hopefully this helps.
- TheHybridWolf
My driver's always been up to date
I looked everywhere on the internet there is no solution to this
but when i had my stock cooler on my cpu this never happend yet the temp went to 70° - 85° degrees
but when i installed my water cooler Seidon 120v V.2 this started to happend like it can't allow the degrees go over 45° or it will like lower the usage on the cpu too cool it down......
But Thanks for answering...
Coolers are Coolers, it shouldn't affect CPU performance in any way either than temperatures.
I think your cpu MAY Be damaged, or its the Mobo, i'm not sure.
If your computer isn't "Custom Made" but rather bought from another company, tell them about it, they might know what's up.
Maybe your bios needs an update, also, not sure.
- TheHybridWolf
Also, maybe hit up the company that sells that water cooler, it may be faulty also, maybe you didn't install it correctly or a valve broke or something like that.
Maybe your PC is dusty as hell, clean it up.
Tiny things can make the biggest consequences.
- TheHybridWolf
The cpu si not damaged, the problem si the cooler, AMD is renown to need the motehrboard VRMs to be cooler actively. When you mounted as water cooler there si no air blowing towards the VRMs. When the VRMs overheat the cpu becaomes unstable or lowering frequemcy. Try to put a small fan to blow towards motehrbaord VRMs adn see if it helps. This is the most common porblem of the AMD FX series or there is a chance that duing mounting of your water cooler you bend a pin or a few pins.
Usually this are the vrms
They might not have a aluminium sink on them, they might have depends on the motherboard. Try to put as small fan to blow directly towards that sink or towards the vrms directly if you dont have sink from a very close range.
This might actually be the problem, please try doing this and selecting Dragos Manea as the answer if it fixes the problem.
- TheHybridWolf
yes and it work's i don't get anymore fps drops thx for helping me on this
