FPS drops to 3 and Audio stutters.
RagezZ
4
When playing any type of game, intensive or not, my computer starts to give me 3 frames on BF4 and on DayZ or a simple platformer. Also the audio starts to stutter and repeat. Any help would be greatly appreciated.
Motherboard: AMD 970 A D3
GPU: Nvidia GTX 760
CPU: AMD FX-8350(4.2 Ghz)
PSU: ThermalTake Black Widow 850W
Alright some things you could do:
1. Run antivirus/antimalware scans
2. Use a program like HWMonitor and report your idle/gaming temps (screenshot would be good)
3. Reinstall graphics drivers
I just checked, and not all of the revisions of that motherboard support that CPU. Could you tell me which revision you have? Only 1.4 and 3.0 support the CPU.
http://www.gigabyte.com/products/product-page.aspx?pid=3908#
You could try a BIOS update.
RagezZ
4
Let me do this and I will see if it works. Thanks!
I have done this and it seems that my CPU is getting less power when I am playing BF4 than being idle.
These are the three wattages off of HWMonitor.
39.02 20.70 45.60 Idle
27.80 19.50 48.40 Loaded
