Question FPS issues despite no obvious bottleneck
Merge.-
11
Hey I’m currently experiencing some fps issues and would really appreciate some advice, GPU and CPU temps less than ~60°C and usage isn’t being pushed past ~ 50%, RAM was at ~95+% so i upgraded to 32GBs, and the issue was initially gone and Overwatch was running around the 600fps cap. For some reason it’s back to running around 180-320 fps with occasional stutters (not just OW, same issue with MW3, Valorant, EAFC) . I’m beginning to think it may be a gpu clock issue as in game it was showing around 1400hz 180-280fps but in the loading screen gpu clock was closer to 2500hz and was running 1400fps (valorant)
MSI B450 Tomahawk Max
Ryzen 7 5800x
7900 XTX
32gb ddr4 3600mhz (patriot viper steel)
2TB HDD
500GB SSD
1440p 360hz AW2725DF
1080p 144hz msi G241
You forgot to mention the make and model of your PSU and it's age. BIOS version for your motherboard? What GPU were you using prior to the 7900XTX ?
Ah yes apologies,
PSU: MSI 1000W GOLD FM MEG A1000G (had for just over a year)
I just updated my bios if thats what you’re asking, as I was reading that could be the issue, so whatever its on whatever the latest is.
Before this GPU I was using a 5600 xt
