Question FPS issues with Final Fantasy 14 ?
Jun 7, 2024
7
Does anyone know what this issue could be? In Final Fantasy 14, the camera movement appears choppy, and it almost seems like there's a constant micro-stutter. This only happens in certain locations, and I can't figure out what's causing it. G-sync and V-sync are both turned on in Nvidia Control Panel.
I have noticed that when I'm able to maintain a constant frame cap of 237 fps, it's smooth as butter. However, as soon as the frames lower even slightly, the stuttering begins.
In the clip below, I'm getting an average of 200 fps, but it feels rough. You can really notice the issue if you find a distant object to look at (such as a building or tree) while the camera is turning. Lastly, I should probably also mention that I'm playing on an Xbox controller connected via Bluetooth.
View: https://imgur.com/a/QAktEGD
CPU: Ryzen 7 7800x3D
CPU cooler: NZXT KRAKEN X73
Motherboard: MSI MAG B650 Tomahawk WiFi - BIOS Ver. 7D75v1H (05/24/2024)
Ram: G.SKILL Trident Z5 Neo DDR5 RAM 32GB 6000MT/s
SSD: SAMSUNG SSD 990 PRO 2TB, PCIe 4.0 M.2 2280
GPU: MSI Gaming RTX 4080 Super 16G Expert
PSU: CORSAIR RMx Shift Series RM1000x (Barely a week of use.)
Chassis: NZXT H710i (white)
OS: Windows 11
Monitor: LG ‎27GS95QE 27-inch Ultragear OLED Gaming Monitor QHD 240Hz 0.03ms
