Build: (about a year old)
*AZZA CSAZ-206S Black SECC ATX Mid Tower Computer Case
*ASRock 990FX Extreme6 AM3+ Northbridge: AMD 990FX Southbridge: AMD SB950 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
*AMD FX-9370 Vishera 4.4GHz Socket AM3+ 220W 8-Core Desktop Processor - Black Edition FD9370FHHKWOX with Liquid Cooling Kit
*CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9B
*SAMSUNG 850 EVO 2.5" 250GB SATA III 3-D Vertical Internal Solid State Drive (SSD) MZ-75E250B/AM
*WD Blue 1TB Desktop Hard Disk Drive - 7200 RPM SATA 6Gb/s 64MB Cache 3.5 Inch - WD10EZEX
*Thermaltake SMART M Series SP-850M 850W ATX12V / EPS12V SLI Certified CrossFire Certified 80 PLUS BRONZE Certified Modular Active PFC Power Supply
*MSI GeForce GTX 960 DirectX 12 GTX 960 2GD5 2GB 128-Bit GDDR5 HDCP Ready SLI Support ATX Video Card
My system, which has been working well for a bit over a year, suddenly started powering down for no apparent reason. If completely cold, it may take 3 minutes to power down. On immediate restart it will power down in about 30 seconds. I managed to look at the voltages and they seem fine. The CPU temp reports 80+ C. The case and fans (including the radiator) are clean with little or no accumulated dust. I guess I am a little suspicious of the CPU cooler and power supply but both should be capable (and are reasonably expensive). Any suggestions on how to trouble shoot or fix this? Thanks!
