Hi, I'm a new builder and I'm having trouble with my front audio plugs.
My motherboard is Gigabyte EP35C-D53R
The case's front audio uses separate connectors and the markings on it are different from the manual.
These are the cables from the case:
Ground
Spkout L
Spkout R
Mic-Bias
Mic-IN
Return R
Return L
And hare are the points for the motherboard according to the manual:
MIC2_L
GND
MIC2_R
-ACZ_DET
LINE2_R
GND
FAUDIO_JD
No Pin
LINE2_L
GND
If anyone could help, thanks.
Ground
Spkout L
Spkout R
Mic-Bias
Mic-IN
Return R
Return L
MIC2_L
GND
MIC2_R
-ACZ_DET
LINE2_R
GND
FAUDIO_JD
No Pin
LINE2_L
GND
