I'm using it as an intake and I don't have an option to change that because of the current PC placement. Fresh air goes in the front, exhausts out the back and top. For now, the fans are behind the radiator and pulling in air through the radiator, which means my RGB fans are not visible at all from the front. I was wondering if I can put the fans on the front of the radiator and still use them as an intake, would that be fine? Would I have to change any other configuration?
Case: Corsair AirFlow 220T
AIO: NZXT Kraken X53 240mm
2x Top and 1x rear fans: exhausts
Front 1x fan + radiator: intake
