So my problem is quiet simple to describe, but caused me a lot of headacke lately.
Somehow my Realtek HDA manager wasn't showing up, but after 2 days of tryharding i managed to make it work prperly. Sound equlizer and every function is jsut fine, but one!
It only works if my headphones connect to the mainboard auio output on the back of my PC, when I plug it into my front Jack, it doesn't work as it is supposed to work. The sound volume has only 2 options:
0: no sound
1-100: max volume, and i can not change it by adjusting the scale
I can manually change the volume inside apps like games or youtube, but not with the bottom right sound icon.
I reinstalled the drives, tryed everything but couldn't find a solution. Tryed multiple drivers already, old ones, the one from the website of the mainboard and from Realtek's site aswell, but the same problem. I checked the BIOS settings and they are just fine.Before I installed the Driver, some default AMD sound made possible to work, and even adjust the volume level, but the queality wasn't that great, that's why I updated the realtek drivers, and the sound adjust problem started there, so it is surely not broken "physically". On the backplane it is perfect, the quality is great and works as it is supposed.
I couldn't find a solution elsewhere, since the only problemsolving threads i found are for "no audio" problems. I clearly have/had audio, it just doesn't work properly.
I have a freshly bought ASRock b450m pro4 board
Thank you for the help, cheers
Photos that might help.
0: no sound
