[SOLVED] Front Panel Connectors
Nov 11, 2019
6
So I just got all pm PC parts and I got a B450 Aorus PRO WIFI motherboard and did not come with front panel connectors like HDD LED, RESET SW, - PLED, and + PLED also my case (Phanteks 350X) just came with a PWR SW. Is this the company's mistake or just need to buy some front panel connectors?
boju
Ambassador
It's not as simple as that. Could probably get standalone leds and reset switches but where are they going to sit? Could probably drill holes in the case and place them near the front fascia somewhere. A project for sure.
Poor case design if you ask me. Perhaps Phanteks thinks reset button and hdd leds are unnecessary.
boju
Ambassador
From 5:43, there's a lot of wires there and a wire tucked just under the white panel in this frame. Should have them all there somewhere.
Regarding the motherboard headers, look at section 15 for F_Panel.
Nov 11, 2019
6
I looked everywhere in the case and only found the Power Switch.
boju
Ambassador
