R rccola2424 Distinguished Jun 28, 2011 98 0 18,630 Aug 10, 2011 #1 Is there a case/case mod out there that's like a controller panel, but also shows things like GPU temp, CPU temp, Ect.?
Solution geofelt Aug 10, 2011 There are some fan controllers with lcd displays like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16811999198 But, I suggest you just add a second monitor. You can use speedfan or other software monitors to display lots of info. Regardless, a second monitor is one of the most useful upgrades.
geofelt Titan Oct 9, 2006 54,896 4,364 174,240 Aug 10, 2011 Solution #2 There are some fan controllers with lcd displays like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16811999198 But, I suggest you just add a second monitor. You can use speedfan or other software monitors to display lots of info. Regardless, a second monitor is one of the most useful upgrades. Upvote 0 Downvote Solution
R rccola2424 Distinguished Jun 28, 2011 98 0 18,630 Aug 10, 2011 #3 Best answer selected by rccola2424. Upvote 0 Downvote
