Question Front pin power and reset locations for ROG Zenith II Extreme Alpha MB
Aug 10, 2023
I am totally confused as to where to place the reset HDD, power and LED pins in the connections provided. The manual does not help at all. Does anyone have an idea on where these go and their polarities? I understand the pins from the case with the arrow indicate positive but cannot figure out on the MB where this goes. I am attaching a CU of the area they are to go on the MB.
Board CU
Are you sure about that? You're motherboard manual's page 1-26, and in conjunction with the image/labelling on the PCB for the motherboard, the left pins are the +ve terminals, meaning the arrowed end of the front panel connector goes.
Make and model of the case you're working with?
Thanks for the link to the manual. The one I have is in Chinese and didnt have an online link to the one in English so that does help. Thinks for the visual too. I have a Thermaltake View71 case.
Latest posts
