Danger Den TDX Waterblock Pic 1 Pic 2
-copper base w/lucite top and 1/2" OD high-flow fittings for 1/2" ID tubing
-currently fits A64 CPUs (sockets 754/939/940)
-buyer can purchase different tops from DD to fit other sockets (roughly $10)
-I'm pretty sure I have all the accelerator nozzles and the socket wrench somewhere around here too
Danger Den DD-D4 12VPump (model in link is a newer version) Pic
-12V connection plugs right into a normal 4-pin molex connector from your power supply
-has two holes in the base for mounting
-padded base for quieter operation
-for use with 1/2" ID tubing
XLR120 Radiator and "The Scoop" Twin 120mm Shroud Pic 1 Pic 2 Pic 3 Pic 4
-custom designed and hand built
-no longer in production and very rare
-radiator has 1/2" OD fittings for 1/2" ID tubing
-includes (2) 120mm aluminum fans
-(at least was) one of the best of radiators
-plastic fans could fit on the inside of the shroud for a more compact profile
Danger Den Single 5 1/4" Bay Reservoir Pic
-1/2" OD fittings for 1/2" ID tubing
-some edges are discolored
-fill cap has a hole in it
-I won't be charging for this since the fill cap has a hole in it and it is discolored on some edges (I'm sure DD will sell or just give you a new fill cap if you call/email them)
Miscellaneous
-(8 ) metal hose clamps Pic
-various lengths of 1/2" ID Tygon tubing (discolored) Pic 1 Pic 2
-bottle of green UV dye (about 80% full, more than enough for multiple water cooling systems)
-bottle of Water Wetter (about 15% full, not sure if that's enough for a system or not; not charging for this)
Group Pic
Everything has been used very, very little. The tubing and reservoir are discolored because I was lazy and didn't drain the system. Otherwise everything is in excellent condition with little to no sign of use. I'm selling it all because basically I'm just too lazy to mess with it anymore and am in dire need of money. I also went from an A64 to C2D, so I'd have to buy a new waterblock top, and I just don't want to put any more money into it. I already have about $350 in it all. If anyone has any quesitons, I'd be happy to answer them.
Total current retail price (new) of the waterblock, pump, and radiator w/shroud is about $250 (that doesn't include tubing, clamps, water additives, etc.). I'm really hoping for any offers starting at about $125 for the complete setup. If anyone is interested in the set or select items only, PM me or email me at oecruiza@gmail.com and we can discuss it, but I'd really rather sell the whole thing at once.
EDIT: Price reduced.
Miscellaneous
Group Pic
