Hi,
I have had my G1.sniper for a while now and the included creative audio chip and software package has been great. (Much better than the Asus D2X I previously had)
The problems however started earlier today.
I first noticed that only the front two speakers were working in the creative volume panel, the same was true with the real speakers, only the front speakers were playing audio.
There was still the picture of the 5.1 speakers and it still said that it was running 5.1.
As I use analogue 5.1 I checked to make sure the jacks were being detected by the software and they were.
I tried restarting, re-plugging the jacks and changing settings on the software but no matter what I did it said it was playing 5.1 but was actually playing 2.0.
So I did the next logical thing, I reinstalled the drivers and software package.
I downloaded the newest driver from the gigabyte website then I uninstalled all of the current software, restarted, did a driver cleaner to delete leftover files and registry entries, restarted then I installed the driver and software package then one last time I restarted to finish and the installation and now my audio won't work at all.
If I go into playback devices I can’t disable or set the default device, simply nothing happens when I click it.
I can't even go into properties for the playback device and disable it.
I change the drop down menu to disabled when I click apply nothing happened even though the apply box greys out like normal.
This is incredibly annoying as I have no audio and cannot talk on Skype as the mic/inputs will not work either.
I really don't want to reinstall windows as my computer is very customised and redoing just the basics takes a few days.
Although this might be a driver/os problem I realise it also may be a hardware one and I suspect if I cannot find help on the net I will need to return the motherboard.
Any help would be appreciated
Thanks
Thanks
