GA-7N400 Pro - CPU Temp
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
I have recently installed the above motherboard with a XP2000 CPU.
It appears the only way I can check the CPU Temperature is rebooting and
going into the BIOS.
I have downloaded a couple of programmes (SiSandra, Speedfan 4.13) that are
supposed to show the CPU temperature on desktop or by the clock. The problem
is, it appears to show the temparature of the board and not the CPU.
Has anyone got any suggestions?
Thanks
Allan
Please ignore..............now sorted
Reset BIOS and now OK
"Allan" <allans2004-btnewsgroups@yahoo.co.uk> wrote in message
news:cdalsf$ome$1@sparta.btinternet.com...
are
problem
> Thanks
> Allan
