GA-X99-UD3P max memory?
16GB sticks supported.
There are more sticks supported than what the QVL shows, though you should attempt to verify any kit you look at.
You can check out pcpartpicker if interested.
EXAMPLE: http://pcpartpicker.com/part/gskill-memory-f42666c15q64gvr
There's a pretty good chance it works. Not sure how to verify absolutely though without buying and testing.
*Note that some BIOS updates include memory profiles for new memory (useful for applying XMP)
Hm.. I saw this mobo with a great price on my country today and I'm thinking about buying this week to start building my pc , but the x16GB modules I couldn't buy now, only on july. So I can not test soon.
If someone have more information would be great
Contact GB and find if they have the support added for 16GB sticks yet. And if so, ask what DRAM they have tested (the chipset is capable, whether they have gotten around to building the support into the BIOS is the question. Others have advertised similar but the support wasn't added in yet. If they say no, might even ask why they are advertising it this way then 😉
They answer me:
"We inform to you that this card model supports up to 64GB of memory. The same supports 16GB modules for this we have a F21a BIOS version that allows compatibility."
I'm afraid about the qualtity of this mobo. At NewEgg there is a lot of bad comments "mobo stop works after 1 week" and lots of people unsatisfied.
