Game randomly begins to stutter and audio repeats.
destinywarlock55
139
Hello!
I mainly play War Thunder and began to experience heavy stuttering and the audio begins to repeat. I started up Task Manager to see if it was a RAM issue since i only have 8GB DDR4 . But ram generally stayed in about 60-70% same for CPU and GPU. I have also tried re-downloading the game.
Specs:
R3 1300X
PNY GTX 1606 6GB
Kingston Hyper X 8GB DDR4
Silicon Power 256GB SSD
Toshiba 500GB HDD (Scraped from an old laptop)
Thank You!!!
P.S. I don't know if this is the correct Category, if it isn't, sorry!
Have you checked temps?
If temps are fine my suspicion is the hdd. Is that 5400rpm model? Often laptops come with 5400rpm drives.
Has the game played fine before? Does it lag straight away or eventually goes to that state? If hdd is a 5400 drive, it's quite possible the pagefile / virtual memory is slowing the pc down as it's usage increases.
destinywarlock55
139
Yeah, the game use to run fine but i dont know whats causing this to happen. And its not installed on the HDD (Yes its 5400rpm), its on the SSD. And it lags straight into the state forcing me to restart the entire PC. I tried closing the window but it apparently lags the PC itself too. Ill have to check using MSI afterburner if it is the VM and for the temps.
P.S. I took a screenshot of Task Manager while i was running an ingame benchmark. https://imgur.com/1DTSErb .
Oh sorry i missed your ssd. Windows is installed on it i assume? If it is it wouldn't be pagefile unless you moved it to the hdd.
Yes do check temps and monitor cpu frequencies while youre gaming with afterburner
JeckeL
630
What all is running that it's eating up that much of your memory/CPU??? I'm assuming the game is responsible for a lot of that, but if the PC remains laggy even after closing the game what're your usage stats like without the game open? While 65% of 8 GB shouldn't cause the symptoms you mentioned it just seems abnormally high unless you've got antivirus updates or windows updates or something running in the background bogging things down
destinywarlock55
139
Sorry it took a while for the response, apparently i cant run MSI after burner cause ithe on screen display doesnt wanna open when i press the binded key.
I mostly just have Spotify, and Steam chat open, including that time oin the screenshot.
destinywarlock55
139
I dont know why, its still not working
Update: its working =D
so far its avg is around 70-72C, but ill tell you the temp when its stuttering.
destinywarlock55
139
Ok, so the GPU temp was around 69C, i was in the hanger (Menu) and it crashed. and now steam thinks the game was uninstalled although i can still open it from the folder.
destinywarlock55
139
I couldn't see the CPU temps, ill check the next time it happens. And do you mean verify Steam files or WT files? cause i cant verify WT since steam doesnt "see" the files anymore (even though its in the steam library folder).
As in the game is listed but says it's not installed?
Id copy the game folder for backup and get steam to reinstall it. Steam should scan the steamapps folder and continue with the files already there, just like if were to copy the whole apps folder to a new hdd / windows install.
Cpu temps is there in the list of osd options in ab.
destinywarlock55
139
Oh thanks with the steam problem. It worked =D. Now im waiting for the PC/ or Game to act up again and watch the CPU temps
destinywarlock55
139
CPU temps are staying at around 48-50C. Sometimes it does spike to 60C
destinywarlock55
139
So, something like 399.24? im on 416.34 right now.
destinywarlock55
139
Sorry if this is a dumb question but, how do i uninstall drivers? Just go to the control panel and uninstall or.......?
destinywarlock55
139
Ill uninstall it from control panel, do i uninstall all of these? https://imgur.com/uaxyK9r or just the ones that end with 416.34?
destinywarlock55
139
Alright, so i just downloaded 399.24 (Fisrt time i tried, it got stuck on 93% and crashed my PC). Ill see if the stuttering continues.
destinywarlock55
139
Alright, it seems like it worked! Thank You!
