Hi, for the last few days my games have been shutting down on their own - it started with apex. About every 15 minutes it shuts down. I tried downloading COD warzone to see if it happens too and again it crashes.
Apex throws : Engine Error 0X887A0006 - DXGI_ERROR_DEVICE_HUNG
COD warzone : View: https://imgur.com/a/fljTYbq
System spec
GPU : ASUS DUAL GeForce RTX 4070 O12GB
CPU : AMD Ryzen 7 7800X3D
PSU : Seasonic Focus GX 750 Gold
SSD : Kingston KC3000 1TB SSD
Mobo: MSI MAG B650 TOMAHAWK WIFI
RAM: G.SKILL 32GB KIT DDR5 6000MHz CL30 Trident Z5 NEO AMD EXPO
What I tried so far :
Reinstall GPU driver
Change settings
Reinstall the game
Change power options
Checked the firewall
Temperatures are OK - cpu max 70 and card max 68
PC is a week after reinstalling to factory settings
Remove and scan the ramps
Run as administrator
Turn off other programs and overlays
Benchmark results :
https://www.3dmark.com/3dm/134079360? - 3dmark
Cinnebench -17615 multithread
https://www.userbenchmark.com/UserRun/70319403 - userbenchmark
Every time it crashed even with all benchmarks the temperatures were ok. Cpu max 75 and card max 66 degrees.
Computer was last reinstalled 10 days ago.
I had a problem in CS2 that the game was tearing horribly but not shutting down.
Do you know what component could be the problem? or what else should I try, thank you
System spec
Change settings
Reinstall the game
Benchmark results :
