Games will not load
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
About 6 months ago, I bought Batman Archam city, (PC, disc version) and while I was able to install the game, was never able to play it. I spent 3 week trying to get it to run, but to no avail (tried reinstall, update drivers etc, etc, etc). The game would load for a few seconds, disc would whir, and then nothing, no error messages, no nothing. Today I bought a new game, fallout 3 GOTY edition, which similarly was another GFWL title. Game installed fine, but again would not load, with exactly the same symptoms as Batman. Now, lastly, just on an whim I grabbed the no cd crack for fallout 3, and the game now loads. Because I want up to date patches etc, I would really like to play both games normally, as I did purchase them. Does anyone have an idea why the games do not seem to be talking to GFWL and not running? I am on win 7. Thanks
You could just download the patches too, they sometimes come with no cd cracks. Also you can try using the old cd crack too.
another solution is to just rip the image file from the disk and then just mount it with alcohol 120 or something.
As for the problem itself, most likely the dvd drive or a driver issue. Not really sure though
The fallout game comes fully patch, and there is a crack for the patched version (1.03) which has the game working perfectly. Unfortunately, the batman patches are not available as manual downloads, nor is there a correct crack available. GFWL support has been less the useless, and I am stuck with game that I am unable to play, but have paid for.
Btw. Just got Batman to work with a crack from gamescopy. However, this is still version one, and the latest is version 1.02. I did manage to find patch 1.01, however, it will not install because it is looking for something in the appdata/GFWL folder that is not there. It seems all of my problems are related to Batman's installation in someway not being registered as a GFWL game.
