Gaming Build Parts
nocternalcalling
6
I would like make sure I have the correct parts before purchasing anything. (First Build).
Parts
Sunbeam AC-9B-HUVB Blue Clear Acrylic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811166032
RAIDMAX HYBRID 2 RX-530SS 530W ATX12V V2.2/ EPS12V SLI Ready CrossFire Ready Modular LED Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817152028
ASUS M4A89GTD PRO/USB3 AM3 AMD 890GX HDMI SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131631
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Dual Channel Kit Desktop Memory Model TW3X4G1333C9
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145218
Western Digital Caviar Black WD5001AALS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136320
LITE-ON Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106335
ZOTAC ZT-40404-10P SYNERGY GeForce GTX 460 (Fermi) 768MB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500173
D
I love that case. Not sure of how high quality it is since I have never used one but it looks great. The rest of the build looks really good except I would avoid that Raidmax power supply and get a quality brand. Look for ~500w units from Corsair , Seasonic , Antec or PC Power and Cooling. You do NOT want to go cheap on a PSU, it can die and take other parts with it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139018
Is a much better choice for close to the same price.
I already have the raidmax power. I'm using it with my current pc. I was thinking about upgrading to a corsair 700w. I've also been using the sunbeam case. The case seems decent. Thought I would break some of the pieces assembling it. I had to take it apart a couple of times and nothing has broken yet. Transferred my old compaq parts to it and temperatures dropped around 10-15 degrees. I have not had any problems with the case. Thanks for the PSU warning.
