Gaming monitor advice
Thewhitepanther
111
hi i was wondering whether it would be feasible to get a 120HZ monitor on a £150 budget and whether a TN or IPS monitor would be best for fps gaming not in any competitive way
Here's my 2 picks for 24" monitors. One of them is the same BenQ you mentioned (good pick on your part). Either are good for your purpose:
http://pcpartpicker.com/parts/compare/asus-monitor-vx248h%2Cbenq-monitor-rl2455hm/
dude first of all tell me what type of gamer actualy you are
Pc gamer with a GTX 660
ok so you just need 1920x1080 coz thats the perfect resolution with full hd ofcos 1920x1080 simply mean full hd so get that BenQ GL2450HM best one dude even low budget that you mention man here is the link best one get that and hpy gaming [ http://www.flipkart.com/benq-gl2450hm-24-inch-led-backlit-lcd-monitor/p/itmdfpqpw7nffhjy?pid=MOND9ZW9AMNZ4FKU&icmpid=reco_pp_same_computerperipheral_monitor_5&ppid=MOND9ZW92KGR98QR ]
ok now thats one is the best for sure coz there is no one out there like this in that price so for sure get that man without even thinking more [ http://www.snapdeal.com/product/lg-215-inches-22en33t-led/1724447403 ] you know one thing i am using it since 3 year and there is no single damn problem showed up
ok now thats one is the best for sure coz there is no one out there like this in that price so for sure get that man without even thinking more [ http://www.snapdeal.com/product/lg-215-inches-22en33t-l... ] you know one thing i am using it since 3 year and there is no single damn problem showed up take that as i said i am currently using it and thats owsm man x lnt realy i am die hard gamer with dashing stuf try that bro go ahead n get that
In my opinion if you are a common gamer and not a self-proclaimed "professional" gamer response times do NOT matter and therefore it does not matter which one you choose although a TN monitor does have less response time.
