So i'm trying to decide on buying a new mouse...
I'm currently using an E-blue cobra (not Junior) Size:126*63.7*38.6mm and while its good for the price I want something with a better senor, and a lager size, I'm claw/palm hybrid gripping the cobra and using it on a low DPI.
previously I've used 2000+ dpi which has resulted in some RSI stuff so i'm finding a lower dpi (400-800) is forcing me to move in a more compound motion instead of isolating the movement just to my wrist.
I've tried using the Logitech G303 (That 3366 sensor tho...) and this is what caused the Rsi crap in the first place, I mean for me it's like navigating an ant... such a shame I loved how it performed but no, its tiny, awkward to hold and hurts Every time I use it 🙁
Sooo that leaves me back to square one, I still have yet to find a decent LARGE mouse which is ambidextrous, not bothered about the side buttons so long as the mouse is symmetrical.
I would like something with a PixArt 3360 sensor, the only thing ive found is a Nixeus REVEL but that's only 125mm long so I don't know if it'll do or not? it might be ok though since its wider than what i'm using?
The other thing ive found is the Cougar 450M that is 135(L) X 67(W) X 40(H) mm BUT has an inferior sensor (PMW3310) and is the same price give or take.
just to add I feel palm grip is going to be the way forward for me.
I'm going to include some photos of my mouse grip for reference.
https://postimg.org/gallery/11l84c93i/
https://s14.postimg.org/67za0psep/IMG_20161012_133709.jpg
https://s14.postimg.org/sl70nitch/IMG_20161012_133714.jpg
https://s14.postimg.org/45ysmgufl/IMG_20161012_134117.jpg
https://s14.postimg.org/4wris8wsx/IMG_20161012_134120.jpg
https://s14.postimg.org/v6clb1iq9/IMG_20161012_134122.jpg
https://s14.postimg.org/bd52w2uq9/IMG_20161012_135327.jpg
Many thanks
Olly.
PS i'm in the UK
Many thanks
Olly.
PS i'm in the UK
