Bigbangin :
Hi
I just built a gaming pc and with summer close I was wondering if I'd be able to run both the AC unit and pc on the same outlet? I have the pc and monitor plugged into a surge protector
You would need to know what kind of Amperage the PC draws and what the AC unit draws (and what else is on that circuit).
The amperage for the AC unit should be on a sticker on it, and you can calculate your PC draw by using online calculators (if you know your hardware). Most home circuits for typical use are 15 or 20 amp max. Worse case, you trip the breaker/blow a fuse, assuming it's using a properly rated one. The breakers have their rating right on them.. figure out which one is yours.
