Gaming pc build need help 1000$ bugdet
FearMeMortals
I need help i want a gaming pc mostly for elder scrolls online and some other games, i plan on connecting the pc to my tv & ive got a mouse & keyboard so 1000$ budget almost forgot, i want it to run these game on ultra of course haha :) If 1000 is to low my max is about 1500$ thanks alot.
Hey man, MMO tend to be CPU intensive, and because of that are less likely to be easy to max out with constant smooth fps. Just a heads up.
What other games do you play btw? Also what country do you live in?
That build isn't a strict gaming build, and 7870's aren't really around anymore. I'd go with a i5/280x or 770 build. Drop the 240gb ssd, get a caviar blue 1 tb, and come out around a little cheaper with much higher fps.
Here is everything on ultra for $1100
PCPartPicker part list: http://pcpartpicker.com/p/3HLZx
Price breakdown by merchant: http://pcpartpicker.com/p/3HLZx/by_merchant/
Benchmarks: http://pcpartpicker.com/p/3HLZx/benchmarks/
CPU: Intel Core i5-4670 3.4GHz Quad-Core Processor ($204.99 @ Amazon)
Motherboard: MSI H87-G43 ATX LGA1150 Motherboard ($74.79 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($69.99 @ Newegg)
Storage: Crucial M500 120GB 2.5" Solid State Disk ($66.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($54.43 @ OutletPC)
Video Card: MSI GeForce GTX 780 3GB TWIN FROZR Video Card ($492.98 @ SuperBiiz)
Case: Corsair 300R ATX Mid Tower Case ($59.99 @ Micro Center)
Power Supply: Antec EarthWatts Green 650W 80+ Bronze Certified ATX Power Supply ($76.98 @ SuperBiiz)
Total: $1101.14
(Generated by PCPartPicker 2014-05-11 01:09 EDT-0400)
And this is what I recommend IF you want to spend $1500
PCPartPicker part list: http://pcpartpicker.com/p/3HM5v
Price breakdown by merchant: http://pcpartpicker.com/p/3HM5v/by_merchant/
Benchmarks: http://pcpartpicker.com/p/3HM5v/benchmarks/
CPU: Intel Xeon E3-1240 V3 3.4GHz Quad-Core Processor ($267.98 @ SuperBiiz)
Motherboard: MSI Z87-G55 ATX LGA1150 Motherboard ($104.98 @ SuperBiiz)
Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card (2-Way CrossFire) ($380.00 @ Newegg)
Power Supply: Antec High Current Gamer 900W 80+ Bronze Certified ATX Power Supply ($129.99 @ Amazon)
Total: $1514.35
(Generated by PCPartPicker 2014-05-11 01:13 EDT-0400)
Here you go. I put in a SSD and HDD, 770. I used a i5-4670k, you could save 15 by not going with a k... I didn't skimp, and you can shave a lot off of this.. Still well with in your $1500 max, and a very nice system.
PCPartPicker part list: http://pcpartpicker.com/p/3HMcS
Price breakdown by merchant: http://pcpartpicker.com/p/3HMcS/by_merchant/
Benchmarks: http://pcpartpicker.com/p/3HMcS/benchmarks/
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($219.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($33.05 @ Amazon)
Motherboard: Gigabyte GA-Z87X-UD4H ATX LGA1150 Motherboard ($149.99 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1866 Memory ($71.10 @ Newegg)
Storage: Samsung 840 Pro Series 128GB 2.5" Solid State Disk ($109.99 @ Amazon)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive ($79.99 @ Amazon)
Video Card: MSI GeForce GTX 770 2GB TWIN FROZR Video Card ($319.99 @ Amazon)
Case: Antec GX500 ATX Mid Tower Case ($55.98 @ Newegg)
Power Supply: SeaSonic 650W 80+ Gold Certified Semi-Modular ATX Power Supply ($99.99 @ Amazon)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($102.98 @ Newegg)
Total: $1243.05
(Generated by PCPartPicker 2014-05-11 01:19 EDT-0400)
Dude... You didn't add in a OS, or CPU cooler... You use random crazy websites and stores which will add in tax.. There is no way those systems will cost that price. You know that, and I know that...
I didn't realize the R9 290s came down in price... I'd get one of them.
*Who is going to build a $1,000 + computer with out so much as a OS or after market cooler?
An aftermarket cpu cooler is absolutely not necessary in a 4670 + H87 motherboard build.
He did not mention that he needed to buy windows. A lot of people do not need to buy windows.
Which one of those stores is "crazy" and "random" because I have bought from all of them except microcenter.
partpicker includes shipping in the cost. Tax is determined by whether or not you live in a state which contains one of the stores warehouses. Your build could contain tax just as easily as mine.
I always add in the a OS, unless they say they don't need it.
They can't add tax into those prices, since it doesn't know where you're ordering from.
I've never seen Newegg add in tax, though it's out of state. Amazon doesn't charge tax in most places.
Not adding a after market cooler only leads to issues. He'll be "that guy" on steam not knowing why his games are running like crap.
You did squeeze some impressive power into such a budget I'll give you that. However, at the price range I like having the total package. Such as, a beefy mobo, high quality storage... That's personal preference though.
Even though they will cost more, your builds did put a lot of power into a cheap package. Nice.
I was very surprised at how cheap the 290's are now! I'd go with a 290 at that price over a 770 any day.
Then remove windows and my build is even cheaper. =D
Good luck tossing 2 "R9 290's" into a $50 case running a CPU without a aftermarket cooler.
I build reasonable systems, that won't be a thermal nightmare waiting to happen.
It is what it is. =D
Honestly, the stock cooler will perform more than adequately at stock speeds for forever assuming there is even a hint of airflow in the case. AMD and Intel would not include it in the box with a warranty if it didn't work. Noise is usually the biggest issue with stock coolers. He can always add one at a later time if he wishes. It certainly doesn't hurt.
I'm pretty sure all online suppliers must charge tax if one of it's warehouses resides in the state of purchase. amazon may be the exception to that somehow.
I normally recommend the Sapphire Tri-X 290 but the WINDFORCEs are on sale at an unbeatable price right now.
I've actually build almost this exact build twice now and neither time did I use an aftermarket cooler, and there are zero problems with temps.
Total: $1101.14
Same RAM, ssd, hdd, gpu. Both builds have a 4570 instead of 4670. Both builds use B85 motherboards. Both builds use Seasonic psus(one Antec)
One build uses $50ish cases with 4 fans.
No issues.
Yea, this one with the 780 makes a lot more sense. I'd still fit in a after market cooler... I mean, it's only $30 bucks. Basically a trade off here, better parts for better GPU. A very good system.
The other one, with two R9's... I mean, I wouldn't make it for a friend. =D
Well here you go, I made adjustments based off of some of your picks to lessen the cost of my first build... I did leave in the aftermarket cooler and windows OS... I stayed with the 770 since it is still a very nice GPU, and can handle ultra at 1080p... I also left in the WD black, I did change to the SSD you picked.
PCPartPicker part list: http://pcpartpicker.com/p/3HNRC
Price breakdown by merchant: http://pcpartpicker.com/p/3HNRC/by_merchant/
Benchmarks: http://pcpartpicker.com/p/3HNRC/benchmarks/
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($34.99 @ Amazon)
Power Supply: Antec EarthWatts Green 650W 80+ Bronze Certified ATX Power Supply ($79.50 @ Amazon)
Total: $1091.30
(Generated by PCPartPicker 2014-05-11 02:35 EDT-0400)
So, if you removed windows and the hyper 212 evo from this build it would be $960.
**Not taking full credit for this, since I used some of your picks. Figured I'd put it down here as a lower cost option. =D
