GeForce GTX 1070 Ti compatible with 500W Power Supply / i5 CPU?
May 19, 2018
Hey guys.
So my current components are the following:
CPU: Intel Core i5 6600K
GPU: Nvidia GeForce GTX 1050 TI 4GB
Power Supply: Corsair Vengeance 500
Mainboard: MSI B150M Pro-VDH (MS-7982)
RAM: 16GB DDR4
I want to upgrade my GPU to a GeForce GTX 1070 Ti.
My Question is:
Is the above hardware compatible with this GPU?
Or is my my Power Supply / CPU to weak?
Thanks!
Yes it is compatible. The Corsair Vengeance is a pretty good power supply and will be plenty for your sysetm with the 1070 Ti.
Your CPU will be good enough for the most part, some games you will see some small CPU limitations. But overall it will be a good setup.
Ok, thank you!
Would it still be enough for a 1080? (A normal 1080, not a TI)
