General overclocking questions.
Afoxi
Ok, first up:
I am running an i7-750 @ 3510MHz, 175MHz*20, but i'm looking to see how far I can push this.
How do I go about fine tuning CPU voltages, as in how do i know how much I need/want to use?
At what temperatures should I start worrying? At 3.5GHz I am currently sitting just under 70^C. I have a Noctua NH-U12P SE2 fan, so I think i can push this a little higher.
Is 80^C normal for a Radeon HD 5870? Is it normal for a GPU to not be able to clock very high? (Tried a +100MHz clock and got artifacts, so i turned it back down to default).
RAM - I run a set of G.Skill Ripjaws PC1333, and wish to know what the ideal CAS settings are. Mine are currently at 9-9-9-24, and i think the "Best" settings are 7-7-7-21.
Thanks in advance!
So in something like Everest TCase would be the Generic CPU Temperature, not the Core temperatures right?
So if Core (TJunction) is 80 at full load and my overall CPU temperature is also 80^C, is this a problem?
