GFX Card Limited By Monitor?
G
Guest
Guest
I have a GeForce2 GTS 64MB (Herculues 3d Prophet II 64 MB). I have noticed that my FPS in Counter-Strike(Half-Life) seems to be limited to the refresh rate of my monitor. If you are familiar with Half-Life, the console command net_graph shows FPS. Lets say I am playing in 1024x960, the max refresh rate of my monitor is 75Hz at that setting, so my FPS won't go above 75. However, If I go below that res. it jumps up to 99 (Counter-Strike never seems to go above 99 FPS). Any explanations, ideas?
It's better to be pissed off than pissed on :)
Turn off your vsync
You can do this in the your display menu
right click on desktop > properties > settings > advanced > GeForce tab (Should be named your chipset or something similar > advanced properties > OpenGl settings will have option right on the tab, Direct3D will have something to the manner of "more Direct3D" button. Set the vertical sync to always off.
This may do it
Also, last time I checked, I'm pretty sure theres a max FPS setting on the servers for Counter-strike, but I don't think thats it if you could increase your frame rate.
thanks a bunch now :) Getting 99 FPS at max resolution in counter-strike now. And ya Half-Life has a variable "fps_max #" to change max fps, won't go above 99 for some reason tho. Oh darn, ONLY 99 fps 😉
